      • Japan
      • Vietnam
Circuit Protection
Circuit Protection
Documents SCHURTER presents ASO Solar Fuse
Join Circuit Protection to participate - click to join for free!
  • Author Author: schurter
  • Date Created: 19 Jul 2011 8:47 AM Date Created
  • Last Updated Last Updated: 7 Oct 2021 10:44 AM
  • Views 517 views
New ASO solar fuse (gPV)
Meets both IEC 60269-6 and UL 2579 photovoltaic standards
The ASO meets both IEC 60269-6 and UL2579 standards for the protection of photovoltaic systems, thus it is qualified for use according to the latest gPV requirements.
The ASO solar fuse has been specifically designed for the protection of photovoltaic systems. This fuse can safely protect PV modules and conductors from reverse over-current conditions.
As PV systems have grown in size, so have the corresponding voltage requirements. This increase in system voltage has typically been intended to minimise power loss associated with long conductor runs. Standard circuit protection devices are not designed to completely protect photovoltaic panels. However, the ASO solar fuse is UL Listed to safely interrupt faulted circuits up to this demanding voltage level.
SCHURTER offers 13 different ampere ratings to match specific requirements of various applications, such as inverters and battery charge controllers or to be used as in-line or string fuse. A PCB version and bolted contacts are also available on request. Moreover, SCHURTER provides the appropriate touch-safe fuse holder (FSO) and fuse clip (231660).
Features and Benefits:
-     Meets both UL and IEC photovoltaic standards (gPV)
-     UL approval for 1000 VDC
-     High breaking capacity of 20 kA @ 1000 VDC
-     Low min. interrupting rating of 1.35 x In
-     PCB version and bolted contacts available on request
Applications:
-     All photovoltaic applications
-     Inverters
-     Battery charge controllers
-     In-line fuses
-     String fuses
Recommended fuse holder and Clip:
-     FSO: touch-safe fuse holder, 35 mm DIN-Rail, 10.3 x 38 mm, 1000 VDC, 30 A
-     231660: Clip, solder THT, 10.3 x 38 mm, 20 A
The product includes UL approval and is RoHS compliant. VDE approval is currently in process. For further information and samples, please contact us at info@schurter.com.sg
Resources:
Technical data ASO http://www.schurter.com/pdf/english/typ_aso_10.3x38.pdf
Stock check https://sapportal.schurter.ch:8888/irj/portal/anonymous
Product News http://www.schurter.com/New-Products/Fuses-Varistors
About SCHURTER Group
The SCHURTER Group is headquartered in Lucerne (Switzerland) since 1933. SCHURTER is an internationally leading innovator and manufacturer of fuses, connectors, circuit breakers, input systems and EMC products as well as a PCB assembly service provider. Our industries span telecommunications, IT, medical and measurement technology sectors, emerging food & beverage and alternative energy industries. The major country-specific certifications including VDE, ENEC, UL, CSA, CCC, METI or KTL are evidence of our high quality and absolute reliability in each product.
Contact: info@schurter.com.sg
Website: www.schurter.com
To Purchase the ASO fuse, go to http://sg.element14.com/ now!
  • fuses
  • fuse
  • ul
  • schurter
  • rohs
  • circuit
  • pcb
  • vde
  • iec
  • pv
  • in-line
  • inverters
  • approval
  • string
  • renewable
  • protection
  • energy
  • solar
  • aso
