Circuit Protection
Circuit Protection
Documents Littelfuse Product News – 807 Series Fuse
Join Circuit Protection to participate - click to join for free!
  • Author Author: jobrook
  • Date Created: 19 Apr 2012 2:16 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:51 AM
  • Views 522 views
Littelfuse Introduces 807 Series TE Time-Lag Subminiature Fuses
New Fuse series is ideal for ballast and commercial LED lighting applicationsimage
The 807 Series of TE time-lag subminiature Fuses provide overcurrent protection on AC circuits. With  a high breaking capacity, 300VAC voltage rating, and best-in-class inrush current withstand capability, the Fuse is designed to open safely under high fault current. Having a compact design of only 7.5mm, the 807 Series Fuse is a smaller pitch alternative to 5x20mm glass cartridge Fuses. Designed in accordance with the IEC 60127-4 standard, the radial lead Fuse gives designers the flexibility of either direct solder or plug-in versions.
     Features:
     - Lead-free and RoHS Compliant
     - Reduced PCB space requirements
     - Direct solderable or plug-in versions
     - Low internal resistance
     - Shock safe casing
     - Vibration resistant
     - Halogen Free
     Applications:
     - Battery Charger
     - Consumer Electronics
     - Power Supplies
     - Industrial Controllers
Check Farnell product offering here
  • fuse
  • lighting
  • circuit
  • littelfuse
  • led
  • circuit_protection
  • led_protector
