Code Exchange
Code Exchange
Forum multiple pre increment/post increment in expression of C language
Join Code Exchange to participate - click to join for free!
  • Replies 35 replies
  • Answers 3 answers
  • Subscribers 53 subscribers
  • Views 19690 views
  • increment
  • c
  • in
  • Code Exchange
  • post
  • single
  • precedency
  • operator
  • left
  • value
  • pre
  • expression
  • right
  • turbo
dr.akshay_1980@yahoo.com
dr.akshay_1980@yahoo.com over 11 years ago
I would like to know the explanation for the following expression evaluation in C under windows TURBO c..
void main()
     int i=4;
    int x;
    x= ++i + ++i + ++i;   // i becomes 5 then 6 added becomes 11 and then incremented to 12 so 11+12=23
    printf("%d",x);
    getch();
when the above was executed value of x comes out to be 21
Slightly eliminating the x variable in the above
void main()
    int i=4;
    printf("%d", ++i + ++i + ++i);   //accordingly at this step  5+6+7=18
    getch();
when the above is executed the answer comes out to be 18
Can anyone provide a decent explanation step by step and why two answers are different???
Thanks in advance.
Akshay
    michaelkellett over 11 years ago in reply to dr.akshay_1980@yahoo.com +3
    If anyone asked you that (kind of) question at an interview (unless, perhaps, the job was to revise the C standard specification) you should explain that the only reasonable approach to such code was to…
  • gadget.iom
    gadget.iom over 11 years ago in reply to dr.akshay_1980@yahoo.com +2
    Ahhh... Complete code usually helps As for the problem... You have fallen victim to undefined behaviour as a result of each compilers interpretation of ambiguous code.
    shabaz over 11 years ago in reply to dr.akshay_1980@yahoo.com +1
    Oh. I now get this is purely an academic question (and a very esoteric one not in my area of interest, sorry!) In real life people wouldn't write that code.. perhaps it is tested nowadays and therefore…
    0 michaelkellett over 11 years ago in reply to dr.akshay_1980@yahoo.com
    If anyone asked you that (kind of) question at an interview (unless, perhaps, the job was to revise the C standard specification) you should explain that the only reasonable approach to such code was to remove it or not write it in the first place. If the interviewer objects to such an answer you should ask for a copy of the relevant C standard and work through it with them out loud (no one should be expected to remember the rules for this kind of silliness).
    If these approaches are not acceptable you don't want to work with such a person (it will end in tears).
  • neuromodulator
    0 neuromodulator over 8 years ago in reply to dr.akshay_1980@yahoo.com
    5+6+7 = 18, while 7+7+7 = 21. When in doubt of what's going on, compilers allow you to check assembly behind each line of code. Now about this specific issue I'm not sure why it's evaluating it differently. I suspect it may me an example of undefined behavior, but to be sure you would have to check the standard. Still nobody would code like that in "real code".
  • phoenixcomm
    0 phoenixcomm over 8 years ago
    This is a great example of what NEVER to do and expect the correct answer.
    int i=4;i=4 ok
    x= ++i + ++i + ++i;
    x= ++i + ++i + ++i;
    What is going on in C is that ++I, (pre-inc),  i++ (post-inc) and as well as +=, -=, *=, /=, and %= are called
    basic mathamatical operators, as well as =, +, -, *, /, %.
    With that being said lets get down to a C statement in BNF: (Backus-Naur Form)
    This grammar was adapted from Section A13 of The C programming language, 2nd edition, by Brian W. Kernighan and Dennis M. Ritchie,Prentice Hall, 1988.
    <unary-expression> ::= <postfix-expression> | ++ <unary-expression> | -- <unary-expression> |
    <unary-operator> <cast-expression> | sizeof <unary-expression> | sizeof <type-name>
    <postfix-expression> ::= <primary-expression> | <postfix-expression> [ <expression> ] |
    <postfix-expression> ( {<assignment-expression>}* ) | <postfix-expression> . <identifier> | <postfix-expression> -> <identifier> | <postfix-expression> ++ | <postfix-expression>
    <unary-operator> ::= & | * | + | - | ~ | !
    <expression> ::= <assignment-expression>  | <expression> , <assignment-expression>
    <assignment-expression> ::= <conditional-expression>  | <unary-expression> <assignment-operator> <assignment-expression>
    <assignment-operator> ::= = | * |  /=  | %=  | +=  | -=  | <<=  | >>=  | &=  | ^= | |=
    In Summary: Well you just can't do it. It is not valid code. In effect, you were making a statement that was like this
    Variable X = prefix-expression operator prefix-expression operator prefix-expression eol.
    POST For all of the folks who thought this was a trick question its not. And yes If you use any language and you put it on your CV or Resume and get it wrong, you should be ashamed of your self. The correct answer to the test question is: Statment is not in legal C syntax. Sorry for being overly critical sometimes but this is not it. I have been working with C since sometime in the 80's, and have written and debugged some compilers. One early on was the DeSmet C compiler and I bit me in the ass when it wouldn't do this terminal[80][] = {{5,5}, ... That took a long weekend a Pauls place.
    FINS
    0 michaelkellett over 8 years ago in reply to phoenixcomm
    I wouldn't expect any one other than a C compiler expert to know if this was valid (by strict interpretation of the relevant standard) code or not.
    I would expect any, even slightly, competent C programmer to recognise it as the kind of code that should never be written.
    The question is not entirely daft, because the messing about with i could be concealed in more complex expression - my compiler (Keil) warns about such things if you do them inadvertently.
  • phoenixcomm
    0 phoenixcomm over 8 years ago in reply to michaelkellett
    No Michael, Any competent C programmer should know this one. Maybe its that you and current programmers put too much reliance on the IDE to tell you, your mistakes.  I am far from an expert.   Instead of making excuses please learn something from this bitter pill.
    Please, moderate your tone a bit - E14 is a nice friendly group, let's keep it that way.
    It's quite possible to have a discussion without recourse to accusing others of "making excuses" because they happen to disagree with you.
    To make it quite clear, I never said that I relied on the IDE to tell me about this (or any other issue), I pointed out that it is flagged as a warning, confirming that in Keil's opinion it is not a good idea but perhaps not, strictly speaking, an error.
    There are many lengthy discussions on this and closely related topics on the web:
    Here is just one:
    https://www.quora.com/What-does-an-expression-involving-multiple-post-pre-decrement-increment-operators-evaluate-to-in-C…
  • phoenixcomm
    Micheal, sorry about that I have been accused of going too far, and well I did this time.  But as a 'programmer' yes I went to school, but not for C (they liked PASCAL at the time), the object as an engineer is to solve problems, not to create them. This subject should never have come up in the first place, as 'operators' are normally taught in the first week or two. And even if you did not go to school pick up a book and read. yes I know that is going out of favor.
    I general have solved problems all my life and yes caused more than a few as I ruffed the feathers, as you see I can be quite blunt and sarcastic.
    But I did write a post about "operators". I don't know why this question keeps popping up. Your Compiler should just throw up errors as a malformed statement. I have seen it on a test once. And I was sucked into this black hole once in an interview where when I told him that the code was invalid they insisted it should work (I stopped the interview with a few choice words and left, a week or so they apologized to me and agreed yes it was malformed and offered me a much better job.)
    About Quora and Stack Exchange. Sometimes when looking for an answer I will look on SE but the questions are "Voted Up/Down" and Mass does not mean right!  So please take it with a grain of salt. Oh and Q just ignore it.
    Now about operator in C and "overloading"  ie x =  i++ + i ++;  Please Please put it back in the black hole it which it lives. No matter what you or anybody else thinks according to K&R (the bible) it can't be done!
  • neuromodulator
    0 neuromodulator over 8 years ago in reply to phoenixcomm
    I gotta disagree with you. Knowing every detail of a language does not make you a better programmer. When solving problems, the focus is on algorithms, not obscure language details.
    Now the expression itself is alright in terms of grammar. Considering that you generate parsers out of the grammar it would make not sense that the compiler does not complain about it.
  • phoenixcomm
    0 phoenixcomm over 8 years ago in reply to neuromodulator
    Please put this fable away. It is Not valid C K&R or ANSI grammar. If you think you can do it you are dead wrong. PLEASE LOOK AT THE GRAMMAR in the K&R book or what portions of which are relevant.
    1. Please Stop whipping this dead horse.
    2. If you really think you are right (snowball's chance in hell) Run the dam gramma with the grammar above. (still, can't be done!)
    3. When you want to say UNCLE and give up, In disgust just apologize for being very very silly.
  • neuromodulator
    Here is my snowball chance in hell:
    From: http://www.open-std.org/JTC1/SC22/WG14/www/docs/n1570.pdf
    x = ++i + ++i;
    expression-statement
    expression;
    assignment-expression;
    unary-expression assignment-operator assignment-expression;
    postfix-expression = conditional-expression;
    primary-expression = logical-OR-expression;
    identifier = logical-AND-expression;
    identifier = inclusive-OR-expression;
    identifier = exclusive-OR-expression;
    identifier = AND-expression;
    identifier = equality-expression;
    identifier = relational-expression;
    identifier = shift-expression;
    identifier = additive-expression;
    identifier = additive-expression + multiplicative-expression
    identifier = multiplicative-expression + multiplicative-expression;
    identifier = cast-expression + cast-expression;
    identifier = unary-expression + unary-expression;
    identifier = ++unary-expression + ++unary-expression;
    identifier = ++postfix-expression + ++postfix-expression;
    identifier = ++primary-expression + ++primary-expression;
    identifier = ++identifier + ++identifier;
