Code Exchange
Code Exchange
Forum Interfacing of SHT11 with PIC24f16KA102
Join Code Exchange to participate - click to join for free!
  • Replies 13 replies
  • Answers 2 answers
  • Subscribers 50 subscribers
  • Views 3294 views
I have written the c code for I2C for interfacing the SHT11(temp sensor) and PIC24F16KA102. but i m not getting the acknowledge from the SHT11 when i m writing through pic.  i m pasting my code here. plz let me know where i m doing wrong if possible. thanks
#include <stdint.h>
#include <xc.h>
#include "main.h"
#include <p24Fxxxx.h>
// ICD Pin Placement Select (EMUC/EMUD share PGC3/PGD3)
//_FICD(ICS_PGx1)
* File:   main.c
* Author: jalpa
* Created on 7 February, 2014, 10:11 AM
//Include section
#include "p24F16KA102.h"
#include "spi.h"
#include "i2c.h"
#include <timer.h>
//Define section
// for input use  PORTBbits.RB7  notation and for output pin use LATBbits.LATB2.
//#define CE LATBbits.LATB2    //pin-6  // CE output pin, PORTB bit 2
//#define SDA_pin LATBbits.LATB9    //pin-22// Clock output pin, PORTB bit 11
//#define SCL_pin LATBbits.LATB8
//#define SDA_dir TRISBbits.TRISB9
//#define SCL_dir TRISBbits.TRISB8
//Declaration of variable
unsigned char msb;
unsigned char lsb;
unsigned char status;
//Declaration of functions
void i2c_init();
void reset_i2c_bus();
void delay_us(unsigned short us);
void i2c_start();
void i2c_restart();
char i2c_send_byte(int data);
char i2c_read_byte();
//#define SCK_dir TRISBbits.TRISB8
//Main function
void main(void)
   // AD1PCFGbits.PCFG0=1;
   // AD1PCFGbits.PCFG1=1;
   AD1PCFG =0XFF;
   //SCK_dir=0;
   i2c_init();
   i2c_start();
   delay_us(2000);
   status = i2c_send_byte(0x03);
   delay_us(10000);
   msb= i2c_read_byte();
   lsb= i2c_read_byte();
   reset_i2c_bus();
void i2c_init()
    int temp;
    I2C1BRG = 157;
    I2C1CONbits.I2CEN = 0;
    I2C1CONbits.DISSLW = 1;
    I2C1CONbits.I2CEN= 1;
    temp = I2C1RCV;
    reset_i2c_bus();
void reset_i2c_bus()  // reset is used before and after a packet i sent through the bus (release both sda and scl)
    int x=0;
    I2C1CONbits.PEN= 1;
    while(I2C1CONbits.PEN)
        delay_us(1);
        x++;
        if(x>20) break;
    I2C1CONbits.RCEN=0;
    IFS1bits.MI2C1IF=0;
    I2C1STATbits.IWCOL=0;
    I2C1STATbits.BCL=0;
    delay_us(10);
void i2c_start(void)
   int x = 0;
   I2C1CONbits.ACKDT = 0;    //Reset any previous Ack
   delay_us(10);
   I2C1CONbits.SEN = 1;    //Initiate Start condition
   Nop();
   //the hardware will automatically clear Start Bit
   //wait for automatic clear before proceding
   while (I2C1CONbits.SEN)
      delay_us(1);
      x++;
      if (x > 20)
      break;
    delay_us(2);
void i2c_restart(void)
   int x = 0;
   I2C1CONbits.RSEN = 1;    //Initiate restart condition
   Nop();
   //the hardware will automatically clear restart bit
   while (I2C1CONbits.RSEN)
      delay_us(1);
      x++;
      if (x > 20)    break;
   delay_us(2);
   int i;
   while (I2C1STATbits.TBF) { }
   IFS1bits.MI2C1IF = 0; // Clear Interrupt
   I2C1TRN = data; // load the outgoing data byte
   // wait for transmission
   for (i=0; i<500; i++)
      if (!I2C1STATbits.TRSTAT) break;
      delay_us(1);
      if (i == 500) {
      return(1);
   // Check for NO_ACK from slave, abort if not found
   if (I2C1STATbits.ACKSTAT == 1)
      reset_i2c_bus();   //error
      return(1);
   delay_us(2);
   return(0);
char i2c_read_byte(void)    //does not reset bus!!!
   int i = 0;
   char data = 0;
   //set I2C module to receive
   I2C1CONbits.RCEN = 1;
   //if no response, break
   while (!I2C1STATbits.RBF)
      i++;
      if (i > 2000) break;
   //get data from I2CRCV register
   data = I2C1RCV;
   //set ACK to high
   I2C1CONbits.ACKEN = 1;
   //wait before exiting
   delay_us(10);
   //return data
   return data;
  unsigned short i;
  // TIMER1 Period = PR1 x 2 x Tosc x Prescale second
  // TIMER1 Period = 145 x 2 x 1/32000000 x 1 = 9 us // practically coming 12us
  PR1=145;                      // Maximum Counter
  T1CON=0x0000;            // TIMER1 Off, Prescale 1:1 using the internal clock
  for (i=0; i < us;i++) {
    TMR1=0;                     // Reset TIMER1 Counter
    IFS0bits.T1IF=0;            // Clear TIMER1 Interrupt Flag
    T1CONbits.TON=1;            // Turn On TIMER1
    while(IFS0bits.T1IF != 1);  // Wait until TMR1 > PR1 (Overflow)
    T1CONbits.TON=0;            // Turn Off TIMER1
    e14 Contributor over 12 years ago in reply to gihu +1
    Hi, thanks Actually i checked the the clock configuration earlier through as u said by LED blinking Code. and for FRCPLL and keeping CLKDIV=0x0000; i m getting Fcy=16MHz. I have checked it by putting different…
    0 e14 Contributor over 12 years ago in reply to gihu
    hi,
    i came to know from the SHT11 data sheet is ...
    The sensor
    cannot be addressed by I2C protocol; however, the sensor
    can be connected to an I2C bus without interference with
    other devices connected to the bus. The controller must
    switch between the protocols.
    i m getting error in the following code. I have taken this code from the one of the post of mikroelectronika (viewtopic.php?f=13&t=13803&start=15) and I have modified only the pins used for SDA and SCL and commented the code for LCD. But i m getting error when i interface PIC24F16KA102 with SHT11 click board. i m pasting my code here. plz help in debugging this problem. i am debugging the following code using MPLABX IDE, C16 compiler. i m getting error in main programme at the following point.
    if(error!=0)
    s_connectionreset(); //in case of an error: connection reset
    * Project name:
    SHT11_driver
    * Copyright:
    (c) Mikroelektronika, 2011.
    * Revision History:
    20111122:
    - initial release (DA and JK);
    * Description:
    This code contains functions for communication with SHT1x temperature and humidity sensor.
    http://www.sensirion.com/en/pdf/product ... -SHT1x.pdf
    * Test configuration:
    SW: mikroC PRO for PIC
    http://www.mikroe.com/eng/products/view ... o-for-pic/
    #include <timer.h>
    #include <math.h>
    typedef union
    { unsigned int i;
    float f;
    } value;
    // modul-var
    //enum {TEMP,HUMI};
    //#include "initlcd.h"
    #define TEMP 0
    #define HUMI 1
    #define PORT_COND TRISBbits.TRISB9 //data port condition: input/output
    #define DATA PORTBbits.RB9 //SHT11 DATA pin
    #define SCK PORTBbits.RB8 //STH11 SCK pin
    #define noACK 0
    #define ACK 1
    //adr command r/w
    #define STATUS_REG_W 0x06 //000 0011 0
    #define STATUS_REG_R 0x07 //000 0011 1
    #define MEASURE_TEMP 0x03 //000 0001 1
    #define MEASURE_HUMI 0x05 //000 0010 1
    #define RESET 0x1e //000 1111 0
    #define MEMORY_ADDRESS 0xA0
    // char* Out_temp()
    // char str[]="Temp:" absolute MEMORY_ADDRESS;
    // return str;
    // char* Out_humi()
    // char str[]="Humi:" absolute MEMORY_ADDRESS;
    // return str;
    char s_write_byte(unsigned char value)
    // writes a byte on the Sensibus and checks the acknowledge
    unsigned char i,error=0;
    PORT_COND = 0; //SHT11 WRITE
    for (i=0x80;i>0;i/=2) //shift bit for masking
    { if (i & value) DATA=1; //masking value with i , write to SENSI-BUS
    else DATA=0;
    SCK=1; //clk for SENSI-BUS
    delay_us(5); //pulswith approx. 5 us
    SCK=0;
    DATA=1; //release DATA-line
    PORT_COND = 1; //SHT11 READ
    delay_us(2);
    SCK=1; //clk #9 for ack
    error=DATA; //check ack (DATA will be pulled down by SHT11)
    SCK=0;
    return error; //error=1 in case of no acknowledge
    char s_read_byte(unsigned char ack)
    // reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
    unsigned char i,val=0;
    { SCK=1; //clk for SENSI-BUS
    if (DATA) val=(val | i); //read bit
    SCK=0;
    DATA=!ack; //in case of "ack==1" pull down DATA-Line
    SCK=0;
    return val;
    void s_transstart(void)
    // generates a transmission start
    // _____ ________
    // DATA: |_______|
    // ___ ___
    // SCK : ___| |___| |______
    DATA=1; SCK=0; //Initial state
    delay_us(2);
    SCK=1;
    delay_us(2);
    DATA=0;
    delay_us(2);
    SCK=0;
    delay_us(5);
    SCK=1;
    delay_us(2);
    DATA=1;
    delay_us(2);
    SCK=0;
    void s_connectionreset(void)
    // communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
    // _____________________________________________________ ________
    // DATA: |_______|
    // _ _ _ _ _ _ _ _ _ ___ ___
    // SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
    unsigned char i;
    for(i=0;i<9;i++) //9 SCK cycles
    { SCK=1;
    SCK=0;
    s_transstart(); //transmission start
    char s_softreset(void)
    // resets the sensor by a softreset
    unsigned char error=0;
    s_connectionreset(); //reset communication
    error+=s_write_byte(RESET); //send RESET-command to sensor
    return error; //error=1 in case of no response form the sensor
    char s_read_statusreg(unsigned char *p_value, unsigned char *p_checksum)
    // reads the status register with checksum (8-bit)
    error=s_write_byte(STATUS_REG_R); //send command to sensor
    *p_value=s_read_byte(ACK); //read status register (8-bit)
    *p_checksum=s_read_byte(noACK); //read checksum (8-bit)
    char s_write_statusreg(unsigned char *p_value)
    // writes the status register with checksum (8-bit)
    error+=s_write_byte(STATUS_REG_W);//send command to sensor
    error+=s_write_byte(*p_value); //send value of status register
    return error; //error>=1 in case of no response form the sensor
    char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
    // makes a measurement (humidity/temperature) with checksum
    unsigned error=0;
    unsigned int i;
    switch(mode)
    { //send command to sensor
    case TEMP : error+=s_write_byte(MEASURE_TEMP); break; //temp
    case HUMI : error+=s_write_byte(MEASURE_HUMI); break; //humidity
    default : break;
    for (i=0;i<65535;i++) if(DATA==0) break; //wait until sensor has finished the measurement
    if(DATA) error+=1; // or timeout (~2 sec.) is reached
    *(p_value+1)=s_read_byte(ACK); //read the second byte (LSB)
    *(p_value) =s_read_byte(ACK); //read the first byte (MSB)
    *p_checksum =s_read_byte(noACK); //read checksum
    return error;
    void init_uart()
    // Initializes the UART so the final data can be sent away, e.g. to a PC
    //9600 bps @ 11.059 MHz
    { SCON = 0x52;
    TMOD = 0x20;
    TCON = 0x69;
    TH1 = 0xfd;
    void calc_sth11(float *p_humidity ,float *p_temperature)
    // calculates temperature [C] and humidity [%RH]
    // input : humi [Ticks] (12 bit)
    // temp [Ticks] (14 bit)
    // output: humi [%RH]
    // temp [C]
    { const float C1=-4.0; // for 12 Bit
    const float C2= 0.0405; // for 12 Bit
    const float C3=-0.0000028; // for 12 Bit
    const float T1=0.01; // for 14 Bit @ 5V
    const float T2=0.00008; // for 14 Bit @ 5V
    float rh=*p_humidity; // rh: Humidity [Ticks] 12 Bit
    float t=*p_temperature; // t: Temperature [Ticks] 14 Bit
    float rh_lin; // rh_lin: Humidity linear
    float rh_true; // rh_true: Temperature compensated humidity
    float t_C; // t_C : Temperature [C]
    t_C=t*0.01-40; //calc. Temperature from ticks to [C]
    rh_lin=C3*rh*rh + C2*rh + C1; //calc. Humidity from ticks to [%RH]
    rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; //calc. Temperature compensated humidity [%RH]
    if(rh_true>100)rh_true=100; //cut if the value is outside of
    if(rh_true<0.1)rh_true=0.1; //the physical possible range
    *p_temperature=t_C; //return temperature [C]
    *p_humidity=rh_true; //return humidity[%RH]
    float calc_dewpoint(float h,float t)
    // calculates dew point
    // input: humidity [%RH], temperature [C]
    // output: dew point [C]
    { float k,dew_point ;
    k = (log10(h)-2)/0.4343 + (17.62*t)/(243.12+t);
    dew_point = 243.12*k/(17.62-k);
    return dew_point;
    void main()
    // sample program that shows how to use SHT11 functions
    // 1. connection reset
    // 2. measure humidity [ticks](12 bit) and temperature [ticks](14 bit)
    // 3. calculate humidity [%RH] and temperature [C]
    // 4. calculate dew point [C]
    // 5. print temperature, humidity, dew point
    //AD1PCFGbits.PCFG0=1;
    //AD1PCFGbits.PCFG1=1;
    AD1PCFG =0XFFFF;
    //AD1PCFGbits.PCFG10=1;
    value humi_val,temp_val;
    float dew_point;
    unsigned char error,checksum;
    //unsigned int i;
    char temp[13];
    char humi[13];
    // Initlcd(); //Initialize LCD
    delay_ms(20);
    while(1)
    error=0;
    error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI);
    //measure humidity
    error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP);
    //measure temperature
    if(error!=0)
    else
    humi_val.f=(float)humi_val.i; //converts integer to float
    temp_val.f=(float)temp_val.i; //converts integer to float
    calc_sth11(&humi_val.f,&temp_val.f); //calculate humidity, temperature
    dew_point=calc_dewpoint(humi_val.f,temp_val.f); //calculate dew point
    //send final data to serial interface (UART)
    // Lcd8_Out(1,1,Out_temp());
    // Lcd8_Out(2,1,Out_humi());
    // FloatToStr(temp_val.f, temp);
    // Lcd8_Out(1,6,temp);
    // FloatToStr(humi_val.f, humi);
    // Lcd8_Out(2,6,humi);
    //----------wait approx. 0.8s to avoid heating up SHTxx----------------------
    delay_ms(1000);
  • gihu
    0 gihu over 12 years ago in reply to e14 Contributor
    Sorry jalpa I did not either realize that the sensor is not I2C... image
    Check this:
    - Put a break point in line:
    Check Data value in the physical Line SDA,
         if 'low', sensor is responding, so put a break point in line
                   Check what was the reason of exit the previous loop, i gets 65536 or D==0, if i gets 65536 the sensor does not end the measurement (remember using Pull-up resistor)
         if 'high', sensor is not responding:
                   - Can you debug your code step by step? (in MPLAB I recommend you using F7 step into, because it is the shortest step). If yes run again the code from the begining, and when start the transmission of the command:
    else DATA=0;
    SCK=0;
    check every time that the status of both lines SCK and SDA are what you are expecting. When the command is sent keep on stepping and check the status of SDA when you get to line
    error=DATA; //check ack (DATA will be pulled down by SHT11),
    If now SDA is low means that sensor works, so maybe it is timing problem,
    Check this, and let us know what you get.
    Sorry for not giving a more concise answer but without the board and the sensor is difficult to try the code...image
    Regards.
    hi..
    i am using the pic24f16ka102 and temperature sensore tmp75 i got the same problem that i got the acknowledge for address but did'nt get the acknowledgement for data
