Connector Technology & Design
Forum Website organization/Simple questions
  • Replies 14 replies
  • Subscribers 129 subscribers
  • Views 2551 views
  • noob
  • stuff
Hi
As a noob to electronics, I'm frequently trying to find the answers to very simple questions both on this site and in greater googleland. Today's incredible time-waster is how to wire a tip jack. After being inundated offsite with where-to-buy, I thought I'd try here since I had some very helpful discussions before, but I can't even figure out how to get something like that started. Is there a beginners guide to this site so I can figure out how it's organized? Somehow, I found enclosures when I needed it, but I'm lost and would like to pose the above simple question to the proper forum. Is there a how-to section for those of us who don't know anything? Just trying to figure out where to post this has proven difficult. Thanks!!
    0 e14 Contributor over 12 years ago in reply to element14jamie
    Jamie: Thanks. Very helpful indeed!!
    Hi -- I figured out what I did wrong above. the right link is http://www.newark.com/emerson-connectivity-johnson/105-0802-001/tip-jack-5700v-10a-red/dp/39F1561?ost=39f1561 Sorry
  • michaelwylie
    0 michaelwylie over 12 years ago in reply to e14 Contributor
    I'm not sure if this is what you're looking for, but:
    With those jacks I mount them first.
    1. Drill an appropriately sized hole in the case/board
    2. Remove the nut
    3. Place the barrel of the jack through the case/board.
    4. Replace the nut and tighten
    Then I solder a wire to the metal contact on the tip jack and use a piece of heat shrink to cover the joint. Finally, the wire is then soldered or connected to its intended circuit.
    0 e14 Contributor over 12 years ago in reply to michaelwylie
    Michael: Thanks for the tip. I hadn't thought about the shrink wrap.
