Connector Technology & Design
Forum What's the worst contemporary connector you could have on a piece of hardware?
  • Replies 23 replies
  • Subscribers 127 subscribers
  • Views 228 views
  • connectors
  • USB 3.0 Micro B
  • Micro-HDMI
  • communication
OwainM
OwainM 1 day ago
Hey everyone,
A small thought experiment came to mind today when discussing what the worst or most inconvenient connector or connector combination you could find on a device is? I'm specifically thinking of obscure or compact variants of common connector standards.
It came to mind when discussing a Sony camera I have which includes Micro-HDMI Output, or the USB 3.0 Micro B port Samsung used on one of their phones a few years ago.
What is the worst still contemporary connector you could find yourself using is?
If you can't think of anything, what is the most inconvenient connector type you once used, that was contemporary at the time?
I'm intrigued to hear what you've had to use, or at least commiserate together Sweat smile.
    dougw 1 day ago +5
    It is really annoying when companies like Apple use a standard connector but use a different pinout from the standard.
    shabaz 1 day ago +3
    SCART : ) Extremely useful, you wouldn't want a TV without it at the time, but impossible to plug in without perfect alignment* (and orientation precise to a degree or so!) - not possible with the back…
  • kk99
    kk99 1 day ago +2
    Mini-USB and Micro-USB were annoying.
    shabaz 1 day ago in reply to OwainM
    A lot of RCA connectors are quite bad because they get used in the wrong environment : ( in-car hi-fi. After a while, poor connection and crackly sound appears : ( One or two mnfr make really nice RCA connectors though; Pomona from memory, their outer connection doesn't loosen as easily.
  • beacon_dave
    beacon_dave 1 day ago
    Not so much the connector itself but rather some of the attempts to make a connector retractable to avoid the need for a cable, but then you end up needing a  cable anyway.
    The current one is a Sony digital voice recorder
    It's probably fine if you are plugging in vertically to a charger socket but not so good directly into the front of a PC, or even the side of a laptop where it may block access to other ports.
    I've been meaning to get a USB A extender with a dock base so as it can stand vertically.
  • beacon_dave
    beacon_dave 1 day ago in reply to shabaz
    A lot don't have an outer connection to start with... bzzzzzz....
    Also ground tends to mate after signal.
