Embedded and Microcontrollers
Blog Altium DXF export
  • Author Author: p.congre
  • Date Created: 23 Jun 2022 10:12 AM Date Created
  • Views 1889 views
  • altium
  • dxf
Altium DXF export
p.congre
p.congre
23 Jun 2022
Hello there,
I am trying to export my PCB design but the polygon is not visible on the DXF.
This is the altium design:
and here is the DXF export:
I don't understand why the circle is full and why the order is empty.
  • dang74
    dang74 over 4 years ago
    I don't know if this will work but you are free to try this.  Generate Gerber files.  Then use Altium's CAM utility to export your desired layer to DXF.
    shabaz over 4 years ago
    It's probably unreasonable to expect DXF output to be directly identical to Gerber, they are for different purposes.
