Embedded and Microcontrollers
Blog Atomically thin ‘switch’: a transistor made from graphene
  • Author Author: ZeroSizeObject
  • Date Created: 8 Feb 2011 9:18 PM Date Created
  • Views 443 views
  • research
  • graphene
  • transistor
  • embedded
  • university
ZeroSizeObject
ZeroSizeObject
8 Feb 2011
Graphene molecular model image.
A new transistor made from graphene, the world's thinnest material, has been developed by a research team at the University of Southampton. The new transistor achieves a record high-switching performance which will make our future electronic devices, such as PDAs and computers, even more functional and high-performance. “Silicon CMOS downscaling is reaching its limits and we need to find a suitable alternative. Other researchers had looked at graphene as a possibility, but found that one of the drawbacks was that graphene's intrinsic physical properties make it difficult to turn off the current flow,” said Dr. Zakaria Moktadir of the Nano research group at the University. Dr. Moktadir discovered that by introducing geometrical singularities (such as sharp bends and corners) in bilayer graphene nanowires, the current could be turned off efficiently. According to Professor Hiroshi Mizuta, Head of the Nano group, this engineering approach has achieved an on/off switching ratio 1,000 times higher than previous attempts. “Enormous effort has been made across the world to pinch off the channel of GFETs electrostatically, but the existing approaches require either the channel width to be much narrower than 10 nanometres or a very high voltage to be applied vertically across bilayer graphene layers. This hasn't achieved an on/off ratio which is high enough, and is not viable for practical use,” he said. Dr Moktadir developed this transistor using the new helium ion beam microscope and a focused gallium ion beam system in the Southampton Nanofabrication Centre, which has some of the best nanofabrication facilities in the world.
Zero
