Embedded and Microcontrollers
Blog CMake: a MACRO can simplify your Pico build
  • Date Created: 27 Aug 2024 12:45 PM Date Created
  • Views 2088 views
  • Likes 11 likes
  • Comments 15 comments
  • raspberry
  • pico
  • cmake
  • vscode
  • teseo_c++
27 Aug 2024
The Pico C/C++ SDK, and its examples, make extensive use of CMake. If you develop projects that use the same principles, you 'll be familiar with the CMake configuration file  CMakeList.txt.
A simple project, that builds a single firmware and relies on the SDK API only, will have a straightforward CMake config file. If your project builds more than one deliverable, the file can get big. You may end up with (almost identical) repeating sections. In that case, a macro can help to keep this manageable. And to maintain integrity of the build when making changes later.
My project C++ library for ST Teseo GPS builds 3 different firmware binaries, and each of them has a UART and I2C version. I used a macro to keep the CMake configuration doable
A CMake macro is very similar to the C parameterised macro. During the project configuration, each declaration that uses the macro, will be expanded. The values used will replace the macro parameters.
Here is my firmware build macro:
# macro to build firmware binary for the examples
macro(__build_firmware example protocol)
message("building firmware for example ${example}, protocol ${protocol}")
add_executable(${CMAKE_PROJECT_NAME}_${example}_${protocol}
        ${CMAKE_CURRENT_SOURCE_DIR}/teseo_${example}.cpp
        ${CMAKE_CURRENT_SOURCE_DIR}/gps_nmea_lib/nmea/nmea.cpp
target_link_libraries(${CMAKE_PROJECT_NAME}_${example}_${protocol}
        ${CMAKE_PROJECT_NAME}_shared_${protocol}
target_include_directories(${CMAKE_PROJECT_NAME}_${example}_${protocol} PUBLIC
# select the debug output (optional, not used by the GPS interface)
pico_enable_stdio_uart(${CMAKE_PROJECT_NAME}_${example}_${protocol} 1)
pico_enable_stdio_usb(${CMAKE_PROJECT_NAME}_${example}_${protocol} 0)
pico_add_extra_outputs(${CMAKE_PROJECT_NAME}_${example}_${protocol} )
endmacro()
The parameters are example and protocol.
Here is the code to build one of the 3 firmware binaries, for both their UART and I2C variant:
# build teseo reply response example --------------------------------------
__build_firmware("reply_response" "uart")
__build_firmware("reply_response" "i2c")
I repeated this for each of the examples. The outcome is that a build all nicely creates all binaries:
building firmware for example reply_response, protocol uart
building firmware for example reply_response, protocol i2c
building firmware for example with_nmea_parse, protocol uart
building firmware for example with_nmea_parse, protocol i2c
building firmware for example nmea_with_data_processing, protocol uart
building firmware for example nmea_with_data_processing, protocol i2c
-rw-r--r-- 1 runner docker 161280 Aug 26 16:31 build/pico_gps_teseo_reply_response_uart.uf2
-rw-r--r-- 1 runner docker 161280 Aug 26 16:31 build/pico_gps_teseo_reply_response_i2c.uf2
-rw-r--r-- 1 runner docker 198144 Aug 26 16:31 build/pico_gps_teseo_with_nmea_parse_uart.uf2
-rw-r--r-- 1 runner docker 198144 Aug 26 16:31 build/pico_gps_teseo_with_nmea_parse_i2c.uf2
-rw-r--r-- 1 runner docker 195584 Aug 26 16:32 build/pico_gps_teseo_nmea_with_data_processing_uart.uf2
-rw-r--r-- 1 runner docker 195584 Aug 26 16:32 build/pico_gps_teseo_nmea_with_data_processing_i2c.uf2
This is one example of how macros can help. Further reading: https://cmake.org/cmake/help/latest/command/macro.html.
Link to all posts.
    Jan Cumps over 2 years ago in reply to scottiebabe
    I'm installing it...
  • scottiebabe
    scottiebabe over 2 years ago in reply to scottiebabe
    Wild. Even the debug probe sort of works with riscv
  • scottiebabe
    scottiebabe over 2 years ago in reply to Jan Cumps
    Yes! The out of box experience has greatly improved. It was technically one radio box check to switch to riscv
    You generated it via that VSCode plug-in, he?
  • scottiebabe
    A riscv blinky.
    This is the cmake list vscode generated
    # Generated Cmake Pico project file
    cmake_minimum_required(VERSION 3.13)
    set(CMAKE_C_STANDARD 11)
    set(CMAKE_CXX_STANDARD 17)
    set(CMAKE_EXPORT_COMPILE_COMMANDS ON)
    # Initialise pico_sdk from installed location
    # (note this can come from environment, CMake cache etc)
    # == DO NEVER EDIT THE NEXT LINES for Raspberry Pi Pico VS Code Extension to work ==
    if(WIN32)
        set(USERHOME $ENV{USERPROFILE})
    else()
        set(USERHOME $ENV{HOME})
    endif()
    set(sdkVersion 2.0.0)
    set(toolchainVersion RISCV_COREV_MAY_24)
    set(picotoolVersion 2.0.0)
    include(${USERHOME}/.pico-sdk/cmake/pico-vscode.cmake)
    set(PICO_BOARD pico2 CACHE STRING "Board type")
    # Pull in Raspberry Pi Pico SDK (must be before project)
    include(pico_sdk_import.cmake)
    project(blink C CXX ASM)
    # Initialise the Raspberry Pi Pico SDK
    pico_sdk_init()
    # Add executable. Default name is the project name, version 0.1
    add_executable(blink
        blink.c
    # pull in common dependencies
    target_link_libraries(blink pico_stdlib)
    if (PICO_CYW43_SUPPORTED)
        target_link_libraries(blink pico_cyw43_arch_none)
    endif()
    # create map/bin/hex file etc.
    pico_add_extra_outputs(blink)
    # add url via pico_set_program_url
    appears similar to other pico projects except
