Embedded and Microcontrollers
Blog division operation with float variable mplabx v6.00 xc16 (v2.00)
  • Author Author: hazard
  • Date Created: 18 May 2024 10:55 AM Date Created
  • Views 1415 views
  • Comments 10 comments
hazard
hazard
18 May 2024
hi every one.
I have some problem trying make some division with float variable.
some one can help me please.
main.c
while(0)
    menu_state = PARAM_MENU;
    param_menu = PARAM_MENU_FREQ;
    pwmq_freq_ui16 = encoder_knob_read();
    set_PWM1_FREQ();
    //set_PWM1_DT();
    sprintf(buffer1,"2-FREQ:%5uHz",pwmq_freq_ui16);
    oled_setcursor(0,2);
    oled_print_string(buffer1);
    return 0;
    // prototype function
    void set_PWM1_FREQ(void)
    PWM1_set_Freq(pwmq_freq_ui16);
pwm.c file
void PWM1_set_Freq(uint16_t Freq_PWM1)
     float Freq_PWM1_F = (float)1/Freq_PWM1;
    //uint16_t new_valor = (uint16_t)((65535*Freq_PWM1_F))/PWM1_CONST_2;
//    if(OC1RS != new_valor)
//        OC1RS = (uint16_t)new_valor;
if I do this        float Freq_PWM1_F = (float)1/;
I get a:
in this moment  ( break point on main.c in line 8     "set_PWM1_FREQ();" )
when I step the line 44 the watches editor clear all the value.
but if I try do this:
pwm.c
    float Freq_PWM1_F = (float)1/1000;
works fine.
I know is confused my discription.
but if some one can try read and help I will aprecciate the kindness.
    genebren over 2 years ago
    You need to declare Freq_PWM1_F outside of the function.  If it is inside a function (as it is now) it is declared on the stack frame, which is not guaranteed to be available after the function call.  I am a little confused to how this was allowed to compile without an error.
  • hazard
    hazard over 2 years ago in reply to genebren
    I hane tryid declare a global variable but the same hapen.
    I think I solve this with:
    double PER_PWM1_F = (double)1/(double)Freq_PWM1;
  • jc2048
    jc2048 over 2 years ago in reply to genebren
    There must be headers, so we aren't seeing it all. No idea where variables are declared and whether they are initialised or not.
    The OP seems to be hacking an existing PWM library.
