Embedded and Microcontrollers
Blog division operation with float variable mplabx v6.00 xc16 (v2.00)
  • Author Author: hazard
  • Date Created: 18 May 2024 10:55 AM Date Created
  • Views 1418 views
  • Comments 10 comments
hazard
hazard
18 May 2024
hi every one.
I have some problem trying make some division with float variable.
some one can help me please.
main.c
while(0)
    menu_state = PARAM_MENU;
    param_menu = PARAM_MENU_FREQ;
    pwmq_freq_ui16 = encoder_knob_read();
    set_PWM1_FREQ();
    //set_PWM1_DT();
    sprintf(buffer1,"2-FREQ:%5uHz",pwmq_freq_ui16);
    oled_setcursor(0,2);
    oled_print_string(buffer1);
    return 0;
    // prototype function
    void set_PWM1_FREQ(void)
    PWM1_set_Freq(pwmq_freq_ui16);
pwm.c file
void PWM1_set_Freq(uint16_t Freq_PWM1)
     float Freq_PWM1_F = (float)1/Freq_PWM1;
    //uint16_t new_valor = (uint16_t)((65535*Freq_PWM1_F))/PWM1_CONST_2;
//    if(OC1RS != new_valor)
//        OC1RS = (uint16_t)new_valor;
if I do this        float Freq_PWM1_F = (float)1/;
I get a:
in this moment  ( break point on main.c in line 8     "set_PWM1_FREQ();" )
when I step the line 44 the watches editor clear all the value.
but if I try do this:
pwm.c
    float Freq_PWM1_F = (float)1/1000;
works fine.
I know is confused my discription.
but if some one can try read and help I will aprecciate the kindness.
  • jc2048
    jc2048 over 2 years ago
    Can the value returned by the read encoder routine be zero? If so, you're going to hit the problem of dealing with a divide by zero error at some point when doing the floating point reciprocal.
    It's possible that that might be what's going on here. The watch variables going to zero hints at a reset, which might be coming from the floating routines throwing an exception (it's a long time since I worked with PICs, and I never used the float stuff much for anything, anyway - they waste too much time in an embedded system where there's a lot going on - so I can't tell you directly).
    Even if it isn't the problem here, it's still a good idea to anticipate it and deal with it in your code.
    You could a) ensure the read encoder never returns zero; b) test for zero just before doing the division and substitute whatever answer you want under those circumstances; or c) understand properly what happens after the float division by zero and deal with it there, either dealing with the trap, if there is one, or handling a NaN or 'infinity' value handed back, if that's what the floating routines do.
    The last may not be very portable - I don't think floating point libraries are very consistent in how they deal with the outcome of a divide by zero.
    shabaz over 2 years ago in reply to jc2048
    I think it might be zero as you say. Impossible to be 100% sure with the limited code provided, but there's a good chance there's a divide by an uninitialized (random) or zero value, since the code has a while(0), which would mean that encoder isn't read, at least not in the snippet of code there.
