Embedded and Microcontrollers
Blog division operation with float variable mplabx v6.00 xc16 (v2.00)
  • Author Author: hazard
  • Date Created: 18 May 2024 10:55 AM Date Created
  • Views 1415 views
  • Comments 10 comments
hazard
hazard
18 May 2024
hi every one.
I have some problem trying make some division with float variable.
some one can help me please.
main.c
while(0)
    menu_state = PARAM_MENU;
    param_menu = PARAM_MENU_FREQ;
    pwmq_freq_ui16 = encoder_knob_read();
    set_PWM1_FREQ();
    //set_PWM1_DT();
    sprintf(buffer1,"2-FREQ:%5uHz",pwmq_freq_ui16);
    oled_setcursor(0,2);
    oled_print_string(buffer1);
    return 0;
    // prototype function
    void set_PWM1_FREQ(void)
    PWM1_set_Freq(pwmq_freq_ui16);
pwm.c file
void PWM1_set_Freq(uint16_t Freq_PWM1)
     float Freq_PWM1_F = (float)1/Freq_PWM1;
    //uint16_t new_valor = (uint16_t)((65535*Freq_PWM1_F))/PWM1_CONST_2;
//    if(OC1RS != new_valor)
//        OC1RS = (uint16_t)new_valor;
if I do this        float Freq_PWM1_F = (float)1/;
I get a:
in this moment  ( break point on main.c in line 8     "set_PWM1_FREQ();" )
when I step the line 44 the watches editor clear all the value.
but if I try do this:
pwm.c
    float Freq_PWM1_F = (float)1/1000;
works fine.
I know is confused my discription.
but if some one can try read and help I will aprecciate the kindness.
  • hazard
    hazard over 2 years ago in reply to genebren
    hi thanks hi allready have tryied this. thanks
  • hazard
    hazard over 2 years ago in reply to javagoza
    hi thanks.
    yes cooret has not been evaluated yet, but when I continue de debug, the division operation is not calculated, the line its step over, and clear the watches editor. but when I put 1000 instead Freq_PWM1 the division is carried out.
    I have step over the problem with another math expression for mapping the OC1RS value.
    but I think this way solve the problem:
    double PER_PWM1_F = (double)1/(double)Freq_PWM1;
    genebren over 2 years ago
    You need to declare Freq_PWM1_F outside of the function.  If it is inside a function (as it is now) it is declared on the stack frame, which is not guaranteed to be available after the function call.  I am a little confused to how this was allowed to compile without an error.
    You might want to try:
    float Freq_PWM1_F = 1.0/(float)Freq_PWM1;
  • javagoza
    javagoza over 2 years ago
    I don't understand what you are asking. It seems to me that you are comparing two different statements.
    This is a constant expression, so the compiler can optimize it.
    In the other case:
    the computed value for Freq_PWM1_F cannot be shown because Freq_PWM1 has not been evaluated yet.
