Embedded and Microcontrollers
Blog Logic Analyzer
  • Author Author: bnpopkin
  • Date Created: 25 Jun 2020 11:03 AM Date Created
  • Views 2031 views
  • Comments 5 comments
Logic Analyzer
bnpopkin
bnpopkin
25 Jun 2020
Hi, I am looking for recommendations on a good logic analyzer.  Can some recommend A few?
Thank you
Brian
bpopkin@gmail.com
    shabaz over 6 years ago +2
    Hi Brian, There's some on the Farnell website. If you want to do very specialist decodes, or high speed protocols, then you need to check if that's supported. Some specialist protocols end up needing particular…
  • bnpopkin
    bnpopkin over 6 years ago in reply to shabaz +1
    Thank you so so so much sir!! i appreciate all the good ideas! Have a fantastic day! be safe out there! brian
  • aswinvenu
    aswinvenu over 6 years ago in reply to shabaz +1
    One really interesting opensource logic analyzer worth mentioning is BeagleLogic. https://beaglelogic.readthedocs.io/en/latest/ If you have an old Beagle Bone Black lying around, Buy a Beagle Logic cape…
  • saadtiwana_int
    saadtiwana_int over 6 years ago
    Hi Brian,
    It depends on your requirements of-course. I have been using a Saleae Logic Pro16 for the past 5 years and can definitely recommend it. I am not sure how high you need to go in terms of frequency requirements for your projects, but as a logic analyzer, it will definitely cover a lot of protocols.
    Another tool that i have used and would recommend is the "USBee" devices. Their protocol decoder feature is especially really good! You should check it out.
    Lastly, if there are certain protocols you work with frequently, you should check compatibility on any device that you're considering buying. Not every device will support everything, while the common protocols (UART, SPI, I2C, etc ) are supported by everyone.
    Lastly, note that the logic analyzers are not very good as oscilloscopes, even though some of them claim to do that too.
    Hope it helps,
    Saad
  • saadtiwana_int
    Hi Brian,
    Hope it helps,
    Saad
