Embedded and Microcontrollers
Blog New hardware boosts communication speed between ‘cores’ on computer chips
  • Author Author: Eavesdropper
  • Date Created: 31 Jan 2011 7:27 PM Date Created
  • Views 479 views
  • research
  • bandwidth
  • data
  • communication
Eavesdropper
Eavesdropper
31 Jan 2011
Computer engineers at North Carolina State University have developed hardware that allows programs to operate more efficiently by significantly boosting the speed at which the ‘cores’ on a computer chip communicate with each other. The core, or CPU, is the brain of a computer chip; most chips currently contain between four and eight cores. In order to perform a task more quickly using multiple cores on a single chip, those cores need to communicate with each other. But there are no direct ways for cores to communicate. Instead, one core sends data to memory and another core retrieves it using software algorithms. “Our technology is more efficient because it provides a single instruction to send data to another core, which is six times faster than the best state-of-the-art software we could find,” said Dr. James Tuck, an assistant professor of electrical and computer engineering at NC State. Tuck goes on to explain the new technology, called HAQu, “It’s not hardware designed to communicate data on its own, but is hardware that expedites data-sharing using existing data paths on a computer chip.” Because HAQu uses these existing data paths, the research team compared it to software communication tools – even though it is a piece of hardware. HAQu is also more energy efficient. “It actually consumes more power when operating but, because it runs so much more quickly, the overall energy consumption of the chip actually decreases,” said Tuck. The next step for the research team is to incorporate the hardware into a prototype system to demonstrate its utility in a complex software environment.
Eavesdropper
