      • Japan
      • Vietnam
PCB Design, Prototyping and Production
PCB Forum PCB Design: Exploring New Ideas and Exciting Challenges
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Replies 9 replies
  • Subscribers 132 subscribers
  • Views 963 views
ariajames_121
ariajames_121 9 months ago
As someone passionate about electronics and embedded systems, I’m always looking for new ways to push the boundaries of PCB design. Whether it's creating compact, high-performance circuits or optimizing power distribution for efficient operation, each project brings unique challenges and learning opportunities.
Right now, I’m excited to work on a new PCB project integrating multiple sensors and wireless communication modules while keeping the design compact and power-efficient. The goal is to build a reliable and scalable solution that can be used for IoT applications, automation, and real-time data processing.
One of the most intriguing aspects of this project is refining the layout to reduce noise and interference while maintaining signal integrity. The use of dedicated ground planes, proper trace routing, and decoupling capacitors plays a critical role in ensuring stable performance. I’m also experimenting with different design software to see which offers the best balance between usability and advanced features.
Another key area I’m focusing on is thermal management. With increasing circuit complexity, managing heat dissipation effectively is crucial. Exploring techniques such as thermal vias, copper pours, and strategic component placement has been an exciting learning experience.
If you’re also into PCB design, I’d love to hear your thoughts! What are some of the biggest challenges you've faced, and what innovative solutions have worked for you? Let’s share ideas and push the limits of what we can create!
  • michaelkellett
    michaelkellett 8 months ago in reply to ariajames_121 +3
    This is a screenshot of a prototype pcb (some on their way here from China right now) - none have ever been built, but its easy enough to share a picture to give an idea of what its like. You could do…
  • ariajames_121
    ariajames_121 8 months ago in reply to Jan Cumps +1
    Thanks for asking! It's still in the prototyping stage, so I don’t have pictures to share just yet, but the idea is to build a compact, low-power board that integrates environmental sensors (like temp…
    Jan Cumps 9 months ago
    What are you making?
  • michaelkellett
    michaelkellett 9 months ago
    Show us some pictures !
    MK
  • ariajames_121
    Thanks for asking!
    It's still in the prototyping stage, so I don’t have pictures to share just yet, but the idea is to build a compact, low-power board that integrates environmental sensors (like temp, humidity, and air quality) along with a wireless module probably LoRa or BLE or remote data logging and monitoring. It's meant to be flexible enough for use in IoT, smart agriculture, or indoor automation setups. Still ironing out the design, especially around minimizing noise from the wireless module.
  • michaelkellett
    You could do the same.
    And following in  dougw footsteps - I invite guesses as to what it might be for !
    MK
  • Andrew J
    Andrew J 8 months ago in reply to michaelkellett
    Crikey, there’s not a lot to go on - a variable power supply with remote control?  Is this an image of the manufactured PCB?  It looks like you have traces over cut out regions and some missing traces.  Yet, given it’s you designing it, I feel like I’m about to learn something new Grinning
  • michaelkellett
    michaelkellett 8 months ago in reply to Andrew J
    The cut outs are not in the board, just the power planes. The semi-split ground plane is a suggestion by the manufacturer of U6 - I'm not that certian that it's a good idea.
    So now you know that the cut outs are for some signal separation and with the added clue of the R and L labels on TP12 and TP11.
    Here's a pic of the board without the ground planes.
    MK
  • Andrew J
    So I’m guessing those traces are not carrying high frequency signals.  It’s a two channel something and I can see a L and R notation on U6 so let me have a stab at a software defined radio?  Or a two channel amplifier?
  • michaelkellett
    I'll wait a bit before letting on - Slight smile
    MK
  • anniel747
    anniel747 8 months ago in reply to michaelkellett
    michaelkellett Most revolutionary internet designs must be kept in utmost secrecy.
