Embedded and Microcontrollers
Blog pdsink: USB-PD 3.2 sink stack for embedded devices
  • Author Author: pvit
  • Date Created: 16 Nov 2025 2:33 AM Date Created
  • Views 814 views
  • power delivery
  • usb_type_c
  • usb_pd
pvit
pvit
16 Nov 2025
USB-C PD is everywhere now, and a lot of embedded designs only need one thing: be a sink and behave correctly. In practice, available PD stacks usually come with at least one hard constraint:
  • vendor lock-in / NDA / no public sources,
  • tied to a specific OS or framework,
  • incomplete feature set on the sink side (e.g. no EPR),
  • behaviour in corner cases that doesn’t really match the spec,
  • difficult to extend to new TCPC / MCU combinations.
For tools, lab gear, and small devices that just want to pull power from a USB-C source, this is mostly noise.
Project
I’ve released a new USB Power Delivery sink stack called pdsink:
  • GitHub: https://github.com/pdsink/pdsink
  • USB-PD Rev 3.2, SPR and EPR modes (sink-side).
  • Platform-agnostic C++ core.
  • Reference: FUSB302B + FreeRTOS.
  • MIT license.
The target is the common “sink” (power consumer) use case, with a small codebase that can actually be read, audited, and shipped in products.
Where it makes sense
Typical use cases:
  • when you need dynamic power control at runtime (heaters, for example),
  • when you want to use an MCU with embedded UCPD and simplify external components,
  • when you need “non-standard” voltages or current limits (via PPS/AVS profiles).
This stack has already been deployed in a real project. If you want an example of an advanced usage scenario (not just demo code), see the reflow table firmware here: https://github.com/puzrin/reflow_micro/tree/master/firmware/src/heater.
