Embedded and Microcontrollers
Blog Why is standardized data so important in embedded systems?
  • Author Author: jlangbridge
  • Date Created: 13 May 2021 2:28 PM Date Created
  • Views 1562 views
  • library
  • units
  • tools
jlangbridge
jlangbridge
13 May 2021
A 193,1 million USD loss because of a bad conversion
December 11th, 1998. The Mars Climate Orbiter blasts off, starting its voyage of over 200 million kilometers to Mars. Its mission was to orbit and survey the red planet, looking at both the atmospheric conditions and any surface changes due to climate. It was part of a project to send several missions to Mars and was to pave the way for future landers.
23rd of September 1999. After a long journey, the Mars Climate Orbiter begins a series of maneuvers to slow its speed and to place itself into orbit. It had been flying on a course calculated with as much precision as possible, but we simply cannot send a probe to another planet without some sort of course correction from Earth. Communications via radio can take anywhere between 5 minutes and 21 minutes, depending on the distance to Earth. Corrective procedures had been previously calculated on the ground and loaded into the onboard flight computer. Everything was ready. Mars Climate Orbiter prepared to burn its thrusters to slow down and enter a stable orbit, the final part of a long trip. During the procedure, it passed behind Mars, severing communications. 21 minutes later, it was supposed to exit the planetary occlusion and resume communications but was never heard from again. The mission was declared a loss two days later.
An electrical voltage can represent any physical quantity...
Most of us are used to switching between scales frequently, often without even knowing it. On a business trip to the US, my American colleague was in shock looking at the thermometer of the car, where the temperature showed 0. I shrugged it off, living in France, I am used to a winter temperature of 0. When I got out of the car, it hit me. He was talking about Fahrenheit when I am used to Celsius. His 0 Fahrenheit was -18 in my Celsius, well below what I was expecting and far below the clothes that I brought for the occasion. The consequences were far less dramatic than the fate of the Mars Climate Orbiter, but it was still a mistake. While it is fairly easy to convert between Fahrenheit and Celsius (take your temperature in Fahrenheit, take away 32, and then divide the result by 1.8 to obtain the result in Celsius), there are other scales that are more complicated.
What about your embedded design? If you are using an LM35 temperature sensor, you are using a precision sensor calibrated for Celsius, one that will deliver 10 millivolts per degree Celsius. On the other hand, if you are using an LM34, you are again using a precision sensor, but one calibrated in Fahrenheit, 10 millivolts per degree Fahrenheit. When you are using this in a design that you control, it is up to you to read the right temperature. The data you receive doesn't have any information identifying what it is. There are no units; there are no scales.
Following the disappearance, an investigation was ordered to understand what happened. The mission was costly, and they had to make sure that whatever brought the mission down never happened again. Several contractors were brought in on a project of this scale, each handling a specific part of the project. It did not take too long to find the culprit, a simple mathematical equation. Ground-based computers ran calculations and fed the results directly to the spacecraft. The ground-based software delivered results in a US customary unit, and the spacecraft accepted those results in SI units. Instead of receiving the anticipated newton seconds, the results were in pound-force seconds, off by a factor of about 4.5, so the thrusters burned much longer than they should have. By simulating what would have happened using these values, it became clear that the angle of attack was too steep and would have brought the spacecraft too close to the surface. It was expected to come within 110 km of the surface but was programmed to enter 57 km, over 20 kilometers below the minimum survivable altitude for the orbiter. It either burnt up in the atmosphere or bounced off the atmosphere and entered a heliocentric orbit, never to be heard from again. An entire mission was lost to a simple conversion.
Bouncing satellites
Embedded scales
We often work best when we have rules to follow, things that must be put in place to achieve a goal. A sort of fail-safe, if you will. Guidelines on how to do things, and everyone must be aware of that. If the tools are good, you probably don't even notice. In large companies that have offices around the world, it is the email client that will change the timezone according to who is invited; if in France I arrive at 8 AM for a business meeting with the US at 8 AM, then I'm going to feel very alone for quite a few hours. In embedded systems, we don't have the processing power of a computer, and we don't necessarily have the luxury of signing every communication and value with a unit. We tend to just say that every time stamp on the network is either local time, or if different timezones are involved, then we'll use GMT, UTC, or something like that (which is basically what happens with Unix and Linux boxes).
There are a few tools and libraries out there that force you to write a specific type of value. Linux has a nice way of telling the system what to use. One tool that I've found is Luos, a library used for inter-microcontroller communications that "forces" you to use SI in transactions, but also proposes a series of tools to convert. The LM34 will output Fahrenheit, the display will also use Fahrenheit, but transparently, this information will transit as Celsius, and if another part of the system needs that information in Celsius, then the conversion is automatic, you don't even need to convert it, or even know what unit your sensor was using in the first place.
    DAB over 5 years ago +3
    Good post. Creating the standards are easy, getting people to use them involves a lot of effort. I spent a lot of time trying to convince engineers to use company standards for work and all I can tell…
  • jlangbridge
    jlangbridge over 5 years ago in reply to DAB +2
    Thanks, DAB! Well, I'm also a lecturer, so I try and get them started early on. Hopefully, none of my students will end up making a 193 million dollar accident! Your typical software engineer is a rather…
    Good post.
    I spent a lot of time trying to convince engineers to use company standards for work and all I can tell you is I got a lot of lip service and very little compliance.
    Some of it was laziness, some of it was fear, and some of it was just hubris that they were better than any standard.
    You have to start at the school level, good luck with that, and then enforce it in the workplace. If only they permitted public hanging?
    The only realistic option is to use Independent Verification and Validation teams to verify the data through each stage of development. A new pair of eyes can usually spot these types of errors. Not always, but most of the time.
  • jlangbridge
    Your typical software engineer is a rather savage animal that doesn't like being told how to do something. And to be fair, I can understand them. Some of the companies I've seen have rather "interesting" management that tells developers how to do something, instead of telling them what to do. So yes, they are pretty sure of themselves. A European team will automatically use Celcius, it's what we use when we make coffee, it's what we hear when we listen to the weather, and it is what we are naturally used to. Water freezes at 0°, water boils at 100°, okay. I want the room to be a nice cozy 21°. Now if an American joins the team, the 21° might still be comfortable, but he is going to read that as Fahrenheit, just because that is what he is used to. When he writes code, he'll naturally write code in Fahrenheit. We are all creatures of habit.
  • jlangbridge
