Embedded and Microcontrollers
DSP Forum Digital Signal Processing
  • Answers 2 answers
  • Subscribers 169 subscribers
  • Views 1835 views
  • dsp
  • fft
martinvalencia
martinvalencia over 11 years ago
I started my thesis project for college, I have little experience in the area of digital signal processing, but enough to start a project; I have a question I could not answer.
How to read the magnitude of a Fourier transform, when using the Fourier transform, to calculate the magnitude of the imaginary and real parts, not achievement convert data to dB?
if there is any reference to this article serious issue of great help if you can share.
The FFT libraries I'm using are these:
Frequency Bin Example
    michaelkellett over 11 years ago in reply to martinvalencia +3 verified
    dB is a ratiometric measurement: If we take the reference amplitude to be r then the amplitude of a signal v in dB is: dBv = 10*log(v/r) When we are talking about electrical signal we are usually much…
  • clem57
    clem57 over 11 years ago +2 suggested
    http://stackoverflow.com/questions/6393257/getting-fourier-transform-from-phase-and-magnitude-matlab has example of the magnitude of both parts. C
    michaelkellett over 11 years ago +1 suggested
    Do you have access to MATLAB - (there are home and student versions at reasonable prices and if you are at college they may have licenses you can use). MATLAB is a really great way to play with Fourier…
  • clem57
    0 clem57 over 11 years ago
    C
  • martinvalencia
    0 martinvalencia over 11 years ago in reply to clem57
    the example you sent me is very simple and easy to understand, I will serve as a reference to start!
    thank you very much for your feedback!
    Best Regards
    Martin V.
    0 michaelkellett over 11 years ago
    MATLAB is a really great way to play with Fourier transforms and signal processing maths in general.  The built in help is as good as most text books and it is really easy to try things.
    I develop almost all of my signal processing stuff for processors or FPGA by starting out by modelling the process in MATLAB.
  • martinvalencia
    0 martinvalencia over 11 years ago in reply to michaelkellett
    I have access to Matlab is a tool widely used in the university where I study.
    I see that you have worked much on this topic:
    My biggest question is the interpretation of the axis of magnitude
    Link (Matlab):
    Fast Fourier transform - MATLAB fft
    I learned to read the Fourier frequency spectrum but for example, in this picture you could see a fundamental harmonic with | Y (t) | = 1 and one with | Y (t) | = 0.5
    But how could convert that data to decibels (dB) ??
    There is some mathematical formula?
    0 michaelkellett over 11 years ago in reply to martinvalencia
    dBv = 10*log(v/r)
    When we are talking about electrical signal we are usually much more interested in power ratios so dBp = 20*log(v/r)
    The v and p are not usually written down.
    So if we have a signal of amplitude 2V and noise of 8mV the signal to noise ratio  would normally be expressed as 20*log(2/.008) = 47.95dB
    There is a reasonable Wiki article:  https://en.wikipedia.org/wiki/Decibel
  • martinvalencia
    Thank you very much, the ratio formula is just what I wanted.
    I really appreciate your help and your feedback!
    Best Regards
    Martin Valencia
