Embedded and Microcontrollers
DSP Forum good FFT library for a non-ARM microcontroller
  • Subscribers 167 subscribers
  • Views 1709 views
  • gcc
  • embedded
  • renesas
  • dsp
  • fft
Jan Cumps
Jan Cumps over 3 years ago
I'm planning to make an FFT project for a Renesas RX microcontroller. Renesas provides a binary lib that works with their proprietary toolchain. It doesn't support GNU/GCC.
Do you know good C or C++ microcontroller-scale libraries that would be portable to another platform? Preferably one you have good experience with.
I've done this before for the ARM CMSIS DSP FFT lib, together with martinvalencia . But that was for a TI Hercules, an ARM controller.
The RX platform that I'm targeting isn't ARM.
If you 've used a good library that you think is portable, let me know....
    shabaz over 3 years ago +4
    Hi Jan, I don't know of anything either, like you I've only used the ARM version. I too would be interested to know of a decent library. If you don't care about efficiency (e.g. for slower sample rate…
  • ggabe
    ggabe over 3 years ago +2
    KissFFT: You can choose fixed or float data type: https://github.com/mborgerding/kissfft
    Hi Jan,
    If you don't care about efficiency (e.g. for slower sample rate applications) then I found this online for FFT computation:
    https://lloydrochester.com/post/c/example-fft/#c-implementation-of-the-fft
    It uses floats, so completely inefficient, but maybe not bad for an experiment, and likely portable. Not everything needs to be speedy, maybe accuracy is needed instead! It seems to work (I checked the Test 2 test vector and result using MATLAB and it was identical).
    It also computes complex FFT but the imaginary portion could be set to zero.
    The code at that web link does work but needed a couple of very minor tweaks in the include file and makefile. If you want to use it then I've placed the code that built for me (on Linux PC) in the FFT tar file here.
  • ggabe
