Embedded and Microcontrollers
Embedded Forum How to write dspic33FJ128GP802 flash memory?
  • Subscribers 503 subscribers
  • Views 426 views
  • write dspic33fj128gp802 flash memory
zhjoy
zhjoy over 7 years ago
Hi ,
I am working on a project which is using dsPIC33FJ128GP802. I am using MPLAB X IDE, XC16 compiler, pickit3.
I need to write flash memory, I thought I have done all procedures, but the code doesn't work.I attached my code here, please help to see where I missed, and how to improve.
In the code, I tried to write flash memory address 0x01000 with data 0x123456.
Please help.
Thanks a lot!
Joy
main.c.zip
  • zhjoy
    I just found a bug in my code, and fixed it, before it is #1000,I changed it to #0x1000. After the modification, temp.i[0] can get 0xFFFF1234, but if I check program memory, address 0x01000, it is still 0xFFFFFF. and if I reset the processor, the first time step here, temp.i[0] is 0xFFFFFFFF again. So, flash memory wasn't written.
    asm("MOV #0x1000,W0"); //an example program memory address
    Where am I wrong, please help.
    Thanks a lot,
    Joy
  • zhjoy
    zhjoy over 7 years ago in reply to zhjoy
    I thought the code works now, it is my verification way is wrong. After I downloaded my code to the processor and run it in debug mode, my expectation was to see in MPLAB X IDE,  the  Program Memory window, in address 0x01000, the data is changed to the new data. I think this is wrong, When I export the data which in temp.i[0] over CAN, the output value is proper.
    Joy
