Embedded and Microcontrollers
Embedded Forum need help to amplify microvolt AC.
  • Replies 14 replies
  • Subscribers 503 subscribers
  • Views 2494 views
  • amplification
  • ac
  • embedded
  • ac amplification
  • electronics
  • microvolts
  • dc
salman34
salman34 over 5 years ago
Hi. I am student doing some research work , I am stuck in something.  I want to convert microvolt AC that i get from some sensor , i want to amplify it upto 5V DC so i can make relation with input and gain.
i tried many circuit and modules but microvolt is very less for them to work. so i need help if anyone give any suggestion.
    dougw over 5 years ago +2
    What frequency is the signal? You will need a very low noise amplifier, probably more than one stage.
    michaelkellett over 5 years ago +2
    More information is needed. What kind of sensor, what frequency range of signals ? shabaz posted what might be a helpful article: Building a Measurement Amplifier MK
  • gordonmx
    gordonmx over 5 years ago +2
    I would be more interested in what issue(s) Ahmed has seen. If it is electrical noise pickup the input impedance may be too high or he may have to put a metal can around the circuit. If noise is being…
  • gordonmx
    I would be more interested in what issue(s) Ahmed has seen.  If it is electrical noise pickup the input impedance may be too high or he may have to put a metal can around the circuit.  If noise is being injected thru the power supply better filtering or separate supplies may be needed.  If the signal you are amplifying is a single known frequency, adding a narrow bandpass filter may help. If the issue is temperature related, thermal insulation may help.  Maybe vibration is a problem.  To go from 100uV to 5V requires a gain of 50,000, so any thing that can cause a shift in the input can be a problem.  In any case, it would be nice to know what problem he is trying to solve.
    Stay Well, Gordon
    shabaz over 5 years ago in reply to michaelkellett
    Awesome : ) It will be great to learn from your experience how easy or hard it is to work with Gowin tools and FPGAs.
    I got a TFT display yesterday so will try to get that up-and-running soon!
    Out of curiosity this is what I see with a 1kHz 100uVp-p signal and the single-stage x 200 amplifier from here:
    I had to string a lot of ferrites on the coax though. It will be nice to put a common-mode choke in the next iteration of the design, but not sure how to do that yet, since the BNC is connected to the enclosure. There are some plastic BNC connectors, so that could be worth experimenting with. I might put the land pattern for a choke on the board, but could be just jumpered across if a plastic connector is not available/used.
    The problem-solver:
    EDIT: Maybe I should put a land pattern for allowing a twisted-pair cable connector like XLR to be used optionally if BNC is not desired.
    michaelkellett over 5 years ago in reply to shabaz
    That looks like about 10uV pk-pk noise, ie about 1.5uV RMS - which I think is about what your amp measured when you blogged it.
    @ Ahmed, if that signal looks very noisy to you, don't despair - if the bandwidth is reduced the noise can be reduced as well.
