Embedded and Microcontrollers
Embedded Forum Can you give me some advices on audio ADC?
  • Subscribers 502 subscribers
  • Views 563 views
Is there anyone can give me some information about the audio ADC that is widely used in the market? It will be highly appreciated if you can response.
  • awinning
    awinning over 17 years ago
    Hi, Could you give me a bit more information. What is the application? Do you require CD quality sound or better?
    e14 Contributor over 17 years ago in reply to awinning
    I am not focusing on any application, I just wanna draw a comparison among the mainstream audio ADCs, so the more information, the better.
  • JohnDSiviter
    JohnDSiviter over 16 years ago in reply to e14 Contributor
    I would suggest going on the manufacturers websites, there are many handy parametric tables (Try TI and ADI for instance).
    There are two main types: successive approximation (usually high quality, high speed) and Sigma Delta which tends to be slower, though ADI and TI make some high speed, high bit versions.
    If you are choosing an audio one for a design, I suggest looking at chips the sound card manufacturers use, they are often well documented, tried and tested and less likely to have supply issues.
    John.
  • edmund
    edmund over 16 years ago
    it all depends on the requirements of the quality of the sound that you will require. Perhaps you can go to this link: http://focus.ti.com/lit/sg/slyb115c/slyb115c.pdf so that you will have a clearer picture of the critical parameters that you will need for your application. Not to mention that nowdays, designers will look for energy efficient chips.
    Cheers
    Edmund Lim
  • edmund
    Cheers
    Edmund Lim
