Embedded and Microcontrollers
Embedded Forum deMUX Help
  • Subscribers 488 subscribers
  • Views 347 views
deMUX Help
Former Member over 16 years ago
Ok so bear with me here, I'm rather new to this kind of stuff. I'm currently doing research in a lab. I know that i need to demultiplex a signal from 1 to 16. I was told to use two 8 output deMUXs to do it. I know that the hardware I'm using will give me the signal, V+, V -, three selection channels, and the ground. I intend to use these deMUX's in a breadboard. Does anyone have any recommendations on what deMUX's I should get?
  • firatkocak
    firatkocak over 16 years ago
    If you need 1 to 16 demultiplexer then why not use 74154 4 to 16 demultiplexer ? No need to use two 8 outputs demultiplexer. It is easy to implement.
    Chers,
    Firat,
    Yes I agree to the previous post.Going with 1:16 would be better.
    Still to answer your question, options are:
    74138 Demux (1:8)  (Inverted Input)
    74154 Demux (1:16)  (Inverted Input)
    FYI
    74159 Demux (1:16)  (same as Input)
    Hope this helps!!
