Embedded and Microcontrollers
Embedded Forum Vertical counter switch debouncing; has anyone used this in a design?
  • Subscribers 495 subscribers
  • Views 387 views
  • 32bit
  • 8_bit
  • 16_bit
  • pic
Catwell over 16 years ago
Vertical Counter switch debouncing just uses a time delay for dealing with switch debounce. After giving it a try in a PIC project of mine, I found it to be a huge waste of clock cycles.
Is there any real benefit of the Vertical Counter?
  • Thomas
    Thomas over 16 years ago
    Hi Cabe,
    A 10 ms delay and retest for the same signal condition only confirms that the input is genuine input and not noise.
    Your concern for lost clock cycles is also genuine. If you can utilize the delay time for some fixed routines within the delay loop, then you are optimizing the code.
    Great thinking.
