Embedded and Microcontrollers
Embedded Forum swing application error on BBB
  • Replies 28 replies
  • Subscribers 504 subscribers
  • Views 3362 views
ramanc51
ramanc51 over 10 years ago
Hi all
          I am getting following error while i run my java swing app through linux script, but no error while executing by java -jar myapp.jar on shell, is there any clue to resolve this error
java.awt.eventqueue3.run
java.security.accesscontroller.doPrevilidged(native method)
java.security.protectiondomain$javasecurityaccessimpl.dointersection
java.awt.eventqueue.dispatchevent
  • clem57
    clem57 over 10 years ago +1
    What is your linux script source?
  • clem57
    clem57 over 10 years ago in reply to ramanc51 +1
    ramanc51 Key message is HeadlessException (Java Platform SE 6) and No X11 DISPLAY variable was set, but this program performed an operati...s it. This means you need X windows environment properly set…
  • mconners
    mconners over 10 years ago in reply to ramanc51 +1
    The one who owns the display is the user that is logged in. You are starting a service as one of the system users, I'm not sure which one, because I don't have access to your system. X11 will prevent users…
  • mconners
    Raman Arumugam wrote:
    Actually my intention is to start my app automatically after BBB boot for that i did following
    That might be a problem for the reasons clem57 stated, you need to have the xserver started prior to running your program.
    1. NO, i am not running as you said, i just tested as given bellow
          cd /usr/bin # i stored my script here
          ./myscript.sh
      Both app are working here, i am also tested as following
        cd /usr/bin
        bash myscript.sh,
    it is also working.
    I'm now confused, is the script working now?
    also, try typing
    echo $SHELL
    to see if it tells you which shell you are running
    or if that doesn't produce anything
    grep <your username> /etc/passwd
    I think you had indicated you are using user debian, so
    grep debian /etc/passwd
    the last entry will tell you your default shell
    Mike
  • ramanc51
    ramanc51 over 10 years ago in reply to mconners
    Hi Mike after changing as you said export DISPLAY=localhost:0.0, i got following error message, QMServer.service is my service to auto start my java app through QMServer.sh
    debian@beaglebone:/usr/bin$ sudo systemctl daemon-reload
    debian@beaglebone:/usr/bin$ sudo systemctl start QMServer.service
    debian@beaglebone:/usr/bin$ systemctl status QMServer.service
    QMServer.service - QMServer
          Loaded: loaded (/lib/systemd/system/QMServer.service; enabled)
          Active: failed (Result: exit-code) since Thu, 18 Feb 2016 20:11:56 +0530; 11s ago
         Process: 1936 ExecStart=/usr/bin/QMServer.sh (code=exited, status=1/FAILURE)
          CGroup: name=systemd:/system/QMServer.service
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.awt.GraphicsEnvironment.createGE(GraphicsEnvironment.java:103)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEn...a:82)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at sun.awt.X11.XToolkit.<clinit>(XToolkit.java:126)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.lang.Class.forName0(Native Method)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.lang.Class.forName(Class.java:264)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.awt.Toolkit$2.run(Toolkit.java:860)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.awt.Toolkit$2.run(Toolkit.java:855)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.security.AccessController.doPrivileged(Native Method)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:854)
    Feb 18 20:11:56 beaglebone QMServer.sh[1936]: at sun.swing.SwingUtilities2.getSystemMnemonicKeyMask(SwingUtilities2....2020)
  • ramanc51
    For command grep debian /etc/passwd, i got following message
    debian:x:1000:1000:Demo User:/home/debian:bin/bash
  • mconners
    Yeah, I don't think that is going to work, you are going to have an issue if you are trying to start this as a service that's running as a different user than the user who "owns" the display.
    That's an X11 security thing. It has been a long time since I have dealt with those kinds of issues, so without having the exact environment in front of me and being able to debug it, I'm not sure I can help much more.
    two things to test though
    temporarily, before starting the service type xhost +, at the command line, this can pose a security risk, but it will open your display to any user until you exit X, or type xhost -
    second, export the DISPLAY variable in your script
    meaning at the top of your script add
    you can try that
    Mike
  • mconners
    That means by default you are running the bash shell, that's good, I just wanted to verify
  • ramanc51
    No luck mike, on your reply you said you are going to have an issue if you are trying to start this as a service that's running as a different user than the user who "owns" the display.
    I don't like or want to try start service that's running as a different user than the user who "owns" the display, please let know the way to auto start my service who own display, please share me step to start my service properly without X-server issue.
  • mconners
    The one who owns the display is the user that is logged in. You are starting a service as one of the system users, I'm not sure which one, because I don't have access to your system. X11 will prevent users from displaying things on your desktop unless you give them permission. Nothing is going to display unless the x server is started prior to the execution of the program.
    There are ways to change the ownership of a process after it starts, at least there is from c, i'm not sure about java.
    This is a problem that has been solved before, hopefully I've given you enough info to formulate google queries that will help you achieve the final steps.
    Look into the commands I had you type
    xhost
    export DISPLAY
    since your program runs from the command line it seems pretty clear to me that the issue is going to be one of a few things
    either the program has no permission to access the DISPLAY
    the program or the environment doesn't know which DISPLAY to acess
    or it's a timing issue from when the application starts and the xserver is started
    Mike
  • clem57
    clem57 over 10 years ago in reply to mconners
    ramanc51
    If this is a command running on a specific user, see Linux Run Command As Another User or Run as Root User. I think you can start your command when you login, read the part of this How To Launch GUI App With Upstart Script - Ask Ubuntu rather than as the init process.
    Clem
  • ramanc51
    ramanc51 over 10 years ago in reply to clem57
    Thank you Clem, issue is solved by the first link reference, this issue is solved by adding following lines in my  myscript.sh
    export DISPLAY=:0.0
    cd /home/debian    // my myapp.jar is  here
    su - debian  -c ´java -jar myapp.jar´
  • ramanc51
    Thank you Mike, your guldens was useful to know actual error that i am facing, as you said export DISPLAY is must to run my app.jar without x11 error, finally i found the user own the display by Clem reference then issue is resolved.
