Embedded and Microcontrollers
Embedded Forum swing application error on BBB
  • Replies 28 replies
  • Subscribers 504 subscribers
  • Views 3370 views
ramanc51
ramanc51 over 10 years ago
Hi all
          I am getting following error while i run my java swing app through linux script, but no error while executing by java -jar myapp.jar on shell, is there any clue to resolve this error
java.awt.eventqueue3.run
java.security.accesscontroller.doPrevilidged(native method)
java.security.protectiondomain$javasecurityaccessimpl.dointersection
java.awt.eventqueue.dispatchevent
  • clem57
    clem57 over 10 years ago +1
    What is your linux script source?
  • clem57
    clem57 over 10 years ago in reply to ramanc51 +1
    ramanc51 Key message is HeadlessException (Java Platform SE 6) and No X11 DISPLAY variable was set, but this program performed an operati...s it. This means you need X windows environment properly set…
  • mconners
    mconners over 10 years ago in reply to ramanc51 +1
    The one who owns the display is the user that is logged in. You are starting a service as one of the system users, I'm not sure which one, because I don't have access to your system. X11 will prevent users…
  • clem57
    Great news! Please share your project here when you get the chance!
    Clem
  • ramanc51
    ramanc51 over 10 years ago in reply to clem57
    sure, but on later i share my project, i need on more guide i want to load my usb-serial converter with specified name that given below, i created my 81-usb-serial.rules in /etc/udev/rules.d, but this rules is not loaded, it always load ttyUSB0/1 or ttyUSB1/0
    SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{serial}=="DJJHDH", SYMLINK+="USB-RS232"
    SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A6008isP", SYMLINK+="USB-RS422"
  • mconners
    Raman Arumugam wrote:
    su - debian  -c ´java -jar myapp.jar´
    Duh. Of course, I can't believe I did't think of that image. I guess I was too focused on the X issues. Glad you got it sorted out.
    Mike
  • clem57
    OMG! ramanc51
         imagePlease do not change because this area is related to driver code that which expects names to be in a known form. Linux is a beast allowing tons of things to change, Even though it can, you must be a developer knowing what source does to change it.
    Clem
  • mconners
    mconners over 10 years ago in reply to clem57
    clem57 , It seems like adding the symlink attribute should be OK.
    Refer to this guide and search for symlink
    Writing udev rules
    KERNEL=="hdc", SYMLINK+="cdrom cdrom0"
    The above rule is probably more typical of the types of rules you might be writing. It creates two symbolic links at /dev/cdrom and /dev/cdrom0, both of which point at /dev/hdc. Again, no NAME assignment was specified, so the default kernel name (hdc) is used."
    Mike
  • mconners
    ramanc51 Since this is a different issue, it should probably be moved into a new thread. That helps people find it in the future.
    Mike
  • ramanc51
    ramanc51 over 10 years ago in reply to mconners
    OK, i posted on separate thread as udev rules error on BBB with more details
  • ramanc51
    Hi mike
                  i tried with different parameter on my rule but no luck, i got error while test my device /dev/ttyUSB0 using udevadm test  /dev/ttyUSB0 as follows
    unable to open device /sys/dev/ttyUSB0, but no file like ttyUSB on /sys/dev folder.
