Embedded and Microcontrollers
Embedded Forum PIC18F67J60 Hardware with problem.
  • Subscribers 502 subscribers
  • Views 174 views
Hi I'm new here, I'm having problems with the hardware is the PIC18F67J60-I/PTPIC18F67J60-I/PT Microchip, I'm using a Fast Jack Halo with filter, the component datasheet says I have to turn the center tape connected to 3.3V core with a 100nF capacitor connected to ground as shown below, but when I connect the same is requested in the datasheet it does not work, and when I disconnect the center tape it works with more packet loss. Would some explain to me what should be happening. I necessarily have to connect the center tape. How does this work?image
