Embedded and Microcontrollers
Embedded Forum Have a question about Micrium's embedded software? Ask our Expert, Matt Gordon
  • Replies 35 replies
  • Subscribers 502 subscribers
  • Views 4519 views
  • applications
  • device
  • embedded
  • kernel
  • micrium
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Embedded in the element14 Community Embedded group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Matt Gordon
Matt Gordon is a senior applications engineer at Micrium.  He began his career developing device drivers, kernel ports, and example applications for Micrium's customers.  Drawing on this experience, Matt has written multiple articles on embedded software.  He also heads Micrium's training program and regularly teaches classes on real-time kernels and other embedded software components.  Matt holds a bachelor's degree in computer engineering from Georgia Tech, Georgia in the USA.
        /* Flag creation code                          */
    OSFlagCreate(&AppFlagEx,                                        /* Pointer to OS_FLAG_GRP structure */
                         "Example Flag",                                    /* String name for flags                        */
                          0,                                                        /* Initial flag values                              */
                          &err);                                                   /* Error pointer                                    */
    void AppTaskA (void *p_arg)
        while (1) {
            OSFlagPend(&AppFlagEx,                                   /* Pointer to OS_FLAG_GRP structure */
                                0x0003,                                          /* Specify bits 0 and 1                         */
                                100,                                               /* Wait for a maximum of 100 ticks       */
                                OS_OPT_PEND_FLAG_SET_ALL,   /* Wait for both flags to be set              */
                                0,                                                   /* No timestamp for this example          */
            Take actions that must follow occurrence of events;
    void AppTaskB (void *p_arg)
        while (1) {
            OSFlagPost(&AppFlagEx,                                   /* Pointer to OS_FLAG_GRP structure   */
                               OS_OPT_POST_FLAG_SET,           /* Indicate that bits will be set                */
            Perform additional work;
    Hey Matt, thank you so much image
    Also, if I want to make a task start from the beginning if I interrupt it in the middle of a task, then do I have an option of using something other than OSTaskDel(). What i mean is suppose my task is printing 1 to 100 and then I interrupt it at 55, now when I want to restart the task but it should start the counting again from 1, insteading of continuing it from 55.
    Regards.
    What happened to the PDF book files?
    1. I am using OSFlagPend(ucos-iii) to block a thread to wait for an event for 180seconds (OS_CFG_TICK_RATE_HZ is 1000u).
    It is working fine i.e when the event is posted my thread is resuming the execution but when it doesn't receive any event within specified time it is getting blocked.
    Normally it should resume execution when timeout happens. Any Ideas?
    2. One more problem is ...delay function OSTimeDlyHMSM is not working, when I used OSTimeDlyHMSM(0,0,30,0,OS_OPT_TIME_HMSM_NON_STRICT ,&oserr); the thread is getting blocked forever.
    Any idea?
    Are you able to determine whether or not tick interrupts are actually occurring?  Both of the problems that you've described could result from the tick interrupt not being initialized properly.
    Hi MattGordon_Micrium,
    Thnaks for the reply.
    the tick interrupt was initialized properly but the problem was the clock frequency( currently assigned cpu_clk_freq=32MHz), it is generating two tick interrupts for a second.
    I think this is the reason for my driver thread getting blocked (as I used 30 seconds which is almost equal to 4hours with two interrupts for a second ).
    When I changed it to cpu_clk_freq / /OSCfg_TickRate_Hz(1000Hz), it is generating too many interrupts per second and the driver is behaving abnormally(suspecting CPU overloaded with tick interrupts).
    Hi MattGordon,
    i'm new in micrium  and i wish to realize a small driver using spi for a wirless module. I'm working on psoc5 and uCos III. I looking for existing project or at least some usefull example.
    Hi, I don't know if you are the right one to ask, but if not, please direct me to the correct person.
    We have bought a MSP Gang programmer from Texas Instruments and I am having some problems communicationg with it. I sent a question to TI's support but there response was "
    In order to resolve your inquiry, we would kindly advise you to contact one of our official distributors..."
    So thats what I am doing.
    Here is the question I sent:
    [Problem:
    My problem is with the MSP Gang programmer. I need to control the programmer from a Labview application using MSP-Gang.dll but I am having problems. Some functions do not work properly and for most function calls Labview returns this error message: "LabVIEW: An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW." Also - the first time I try to run the dll after starting my PC, Labview crashes. Is the dll not compatible with Labview 2012 and windows 7? /Stephan]
    [Steps Needed to Recreate Problem:
    Use MSP-Gang.dll with Labview 2012 and windows 7.
    Regards
    Stephan.
    Stephan,
    The section for questions about the Micrium Real Time Operating System may not be the best place to ask questions about LabView and TI programmers, but here is a little information that might help.
    http://www.farnell.com/datasheets/1681622.pdf
    "Together with the MSPGANG.dll are provided two more files that should be used during the compilation process.
    • MSP-GANG.h: This file is the header file for the MSP-GANG.dll, and provides the function prototypes,
    typedefs, #defines, and data structures for the functions of the MSP-GANG.dll. This file is normally
    located in the same directory as the application source file and should be included by the application
    source files. This file is used during compile time.
    • MSP-GANG.lib: This file is the library file for the MSP-GANG.dll and is required to access the DLL
    functions. This file is normally located in the same directory as the application source file and should
    be added to the Linker Object / Library Modules list of the application. This file is used during link time."
    "Examples of using the new MSP-Gang.dll are provided and can be found in these locations (if the default
    installation directory was used):
    C:\Program Files\Texas Instruments\MSP-GANG\Examples\C_Applications_MSP_DLL
    and
    C:\Program Files\Texas Instruments\MSP-GANG\Examples\Cpp_Applications_MSP_DLL"
    "The Gang430.dll wrapper allows application software prepared for the old MSP430 Gang programmer to
    control the new MSP-GANG programmer via the MSP-GANG.dll. Because the MSP- GANG programmer
    has different functionality and features than the old MSP430 Gang Programmer, not all features provided
    in the old programmer are supported in the same way by the MSP-GANG programmer."
    "See the MSP430 Gang Programmer (MSP-GANG430) User's Guide (SLAU101) for list of commands used
    in Gang430.dll."
    http://www.ti.com/lit/ug/slau101q/slau101q.pdf
    http://www.ti.com/tool/msp-gang430
    MSP-GANG430
    MSP430 In-System Gang Programmer Status: OBSOLETE
    Hi matt,
    I have been trying to port Micrium TCP/IP stack (version 2.13.01) to STM32 platfrom.
    I am finding it difficult to configure/enable ARP feature in uC-TCP/IP
    -> When Applicaiton tries to send a IP Packet, I don't see uC-TCP/IP Stack sending ARP-request at lower-layer driver, to get MAC Address of destination
    Can you please guide me, how to trigger Micrium TCP/IP Stack to send ARP-requests and handle incoming ARP Requests with ARP responses ?
    Thanks in advance.
    -Regards,
    Ram.
