Embedded and Microcontrollers
Embedded Forum Way to resolve RXTX mismatch warning on BBB with debian
  • Subscribers 502 subscribers
  • Views 253 views
ramanc51
ramanc51 over 10 years ago
if anybody facing this warring then follow this steps, this steps for stable  RXTX-2.1-7 version
  1. Remove old librxtxSerial.so file from arm folder of jre installed in my BBB it is located  under /usr/java/jre/lib/arm
  2. Download your rxtxSerial.so that suitable to your jre version from https://blogs.oracle.com/jtc/entry/serial_port_communication_for_java
  3. Copy it into arm folder of your installed jre in your BBB
  4. Rename it to librxtxSerial.so
  5. Start your java app, now you will get same version of java lib and native lib(my java lib version is RXTX-2.1-7)
