Embedded and Microcontrollers
Embedded Forum Do you have a question on Embedded electronics and controls? Ask our Expert, Paul Clarke
  • Replies 126 replies
  • Subscribers 508 subscribers
  • Views 10650 views
  • skills
  • c
  • hvac
  • digital
  • engineer
  • expert
  • microprocessor
  • answer
  • control
  • thermal_management
  • embedded_system
  • embedded
  • thermal
  • electronics
  • paul_clarke
  • assembly
  • solutions
  • rac
  • software
  • develop
  • question
pjclarke
pjclarke over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Embedded in the element14 Community Embedded group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Paul Clarke
Paul has 20+ years of working as a digital electronics engineer and has strong software skills in assembly and C for embedded systems. Currently developing embedded electronics for thermal management control solutions for the air movement industry (HVAC & RAC).
    hello SIR,
    i just have basic question regarding the working of crystal oscillators attached with the microcontrollers?
    as the microcontrollers works on the square wave clock, which are digital in nature,
    but the crystal oscillator is an analog defvice which produces sine waves,
    so my question is that how these sine wave signals are converted to square wave signals???
    and if i use crystal oscillator of 40MHz instead of 12MHz, then what will happen???
    --the execution time of the program will be fast OR
    --the transmission baud rate will be increased??
    Hello Paul,
         So my buddies and I are doing a project, we are building a 8051 digital-clock and thermo, we have the code that was offered by Element14. We were looking for an assembler software program. We use Proview32 at school, but would like to work on project from our houses also. Don't have the software large enough for the file. Kiel only carries the 2Kb memory. We need a larger memory holder. Any ideas or suggestions?
    Thanks for your time and consideration,
    George Voight
    michaelkellett over 13 years ago in reply to e14 Contributor
    You don't say which 8051 you are using so this may not help !
    Try http://www.silabs.com/products/mcu/Pages/8-bit-microcontroller-software.aspx#ide
    As far as I can see this toolset is based on Keil but free and unrestricted for use on Silabs 8051 chips. The Silabs parts are about as good as 8051 ever gets so using them is a good plan any way.
    I do have some questions:
    why are you usng 8051
    why are you coding in assembler
    what does your clock thermometer do that's so special you can't fit the code in 2k
    where is the Element14 code you refer to
    With answers to these I might be able to be more helpful.
    Michael Kellett
    hello sir nice to meet u
                                sir  now i start to learn how to serial interfacing in 8051.i write the code for serial communication the program is working but it isnot logic can u please expline me sir. in this program,i remove  the fuctions of lcd(),lcdcmd(),display(),in while loop or before while the program is not display before rf module read rfid serialy. otherwise rfmodule read after rfid.display is working. it is read befoer rfid the functions are write both side befoer while after while.it is displaied.what is the problem it is not logic. pleace explain me sir
    #include<reg51.h>
    #include<stdio.h>
    #include<string.h>
    sbit rs=P2^0;
    sbit rw=P2^1;
    sbit en=P2^2;
    unsigned char tem[9];
    void serialrx();
    void cmp();
    void lcdcmd(unsigned char l);
    void lcddata(unsigned char l);
    void display(unsigned char *dr);
    //void delay(unsigned char s);
    void delay(unsigned char l);
    void lcd();
    P1=l;
    rs=0;
    en=1;
    rw=0;
    en=0;
    P1=l;
    rs=1;
    en=1;
    rw=0;
    en=0;
    while(*dr)
      lcddata(*dr++);
      while(l--);
    void lcd()
         lcdcmd(0x0c);
         delay(6);
    lcdcmd(0x38);
    delay(6);
         lcdcmd(0x06);
         delay(6);
    void main()
            lcd();
        lcdcmd(0x80);
    delay(1000);
        display("WARRIOR TRANS");
    delay(1000);
    lcdcmd(0xc0);
    delay(1000);
        display("MISSION TOOL");
    while(1)
        lcd();
        lcdcmd(0x80);
    delay(1000);
    delay(1000);
    lcdcmd(0xc0);
    delay(1000);
    serialrx();
         cmp();
    void cmp()
    int a;
    char b[9]="16722482";
      a=strcmp(b,tem);
    if(a==0)
         lcd();
    lcdcmd(0x80);
    display("                           ");
         delay(1000);
    lcdcmd(0x80);
         display("AUTHORISED");
    delay(1000);
    lcdcmd(0xc0);
    display("                           ");
         delay(1000);
    lcdcmd(0xc0);
         display("          TOOL ");
    else
          lcd();
    lcdcmd(0x80);
    display("                           ");
         delay(1000);
    lcdcmd(0x80);
         display("UNAUTHORISED");
    delay(1000);
    lcdcmd(0xc0);
    display("                           ");
         delay(1000);
    lcdcmd(0xc0);
         display("          TOOL ");
    void serialrx()
    int i;
        TMOD=0x20;
        TH1=0xfd;
        SCON=0x50;
        TR1=1;
    for(i=0;i<8;i++)
       while(RI==0);
         tem[i]=SBUF;
            RI=0;
      tem[i]='\0';
    hi paul sir nice to meet u
    #include<reg51.h>
    #include<stdio.h>
    #include<string.h>
    sbit rs=P2^0;
    sbit rw=P2^1;
    sbit en=P2^2;
    void serialrx();
    void cmp();
    void lcd();
    P1=l;
    rs=0;
    en=1;
    rw=0;
    en=0;
    P1=l;
    rs=1;
    en=1;
    rw=0;
    en=0;
    while(*dr)
      lcddata(*dr++);
      while(l--);
    void lcd()
         lcdcmd(0x0c);
         delay(6);
    lcdcmd(0x38);
    delay(6);
         lcdcmd(0x06);
         delay(6);
    void main()
            lcd();
        lcdcmd(0x80);
    delay(1000);
    delay(1000);
    lcdcmd(0xc0);
    delay(1000);
    while(1)
        lcd();
        lcdcmd(0x80);
    delay(1000);
    delay(1000);
    lcdcmd(0xc0);
    delay(1000);
    serialrx();
          cmp();
    void cmp()
    int a;
      a=strcmp(b,tem);
    if(a==0)
         lcd();
    lcdcmd(0x80);
    display("                           ");
         delay(1000);
    lcdcmd(0x80);
    delay(1000);
    lcdcmd(0xc0);
    display("                           ");
         delay(1000);
    lcdcmd(0xc0);
         display("          TOOL ");
    else
          lcd();
    lcdcmd(0x80);
    display("                           ");
         delay(1000);
    lcdcmd(0x80);
    delay(1000);
    lcdcmd(0xc0);
    display("                           ");
         delay(1000);
    lcdcmd(0xc0);
         display("          TOOL ");
    void serialrx()
    int i;
        TMOD=0x20;
        TH1=0xfd;
        SCON=0x50;
        TR1=1;
    for(i=0;i<8;i++)
       while(RI==0);
         tem[i]=SBUF;
            RI=0;
      tem[i]='\0';
    Could you please tell me or send me the details of your project " ELECTRONIC CODE LOCK SECURITY SYSTEM " ? Details like Circuit Diagram and Components used in the circuit. My email ID is razkr321@gmail.com . After understanding the complete project I can understand what changes should be done in programming.
    Hi
    Arbaaz Mandlik
    Could you please tell me or send me the details of your project " ELECTRONIC CODE LOCK SECURITY SYSTEM " ? Details like Circuit Diagram and Components used in the circuit. my email ID is razkr321@gmail.com . After understanding the complete project I can understand what changes should be done in programming.
  • kevin@ukbiznet.co.uk
    kevin@ukbiznet.co.uk over 13 years ago
    Hi Michael
    Thanks for the reply Iam using a Vellemam USB VM140 but at some point I will need to brake the connection and use embedded I think the ST Cortex is my best option then especially due to its extra processing power
    Kevin..
    HII
    hardwear detail:-
    TMS320C5515(DSP KIT)
    TELIT GL865(GSM/GPRS modem)
    TXS0102(voltage level converter)
    softwear problem:-
    code composer studio v5
    window 7 (64 bit)
    code in c language
    i want to send AT command to TELIT GL865 from TMS320C5515 (without using PC) ,but i am not getting OK respose from TELIT
    i am useing following code to transmit AT command
    void UartTxChar(unsigned char ch)  //function to transmit character
              CSL_Status status;
              while (((hUart->uartRegs->LSR) & (0x0020)) != 0x0020);
              status = UART_write(hUart, &ch, 1, 0);
              if(status == CSL_SOK)
                                    // printf("\n  sent %c",ch);
                                  else
                                            //printf("\n  Write Failed");
              //USBSTK5515_waitusec(1000);
              //while(command != ch );
    void UartTxString(unsigned char *str) //function to transmit string
    while(*str != '\0')
    UartTxChar(*str++);
    UartTxChar(0X0D);
    UartTxChar(10);
    USBSTK5515_waitusec(25000);//put it to wait for sending
    USBSTK5515_waitusec(2500000);//put to wait for the ok
    and cde to recive ok
    void uart_rxIsr(void)
              //printf("rxc");
    //UART_read(hUart,&command,1,0);
              command = CSL_FEXT(hUart->uartRegs->RBR,UART_RBR_DATA);
              //if (command == 's')
              //          gcount = 1;
    //                    dsp_call = 0;
        Recv[etc] = command;
        for( j = 0; j<=5; j++ )
         printf("%c",Recv[j]);
        etc++;
    i am not able to find out where is problem and what is it
    plz help me to solve this problem
    Hii,,
    I recently made a small project for my final project,
    This project involves the transmission of data via the serial port.
    I am using proteus to simulate the system as a whole and based on ATmega16.
    since my laptop does not have a serial port so I
    using Virtual Serial Port Emulator. While I use huperterminal to receive data transmitted by the microcontroller. I just do not have the data sent by the microcontroller.
    Someone please help me, I've thought about it for hours and did not manage to make the data sent ..
    This is a screenshot of proteus and code. ..
    //Program for ADC to read from channel 0 and show the 8 bit o/p on PORTB
    // send the reading from ADC to Serial Port
    #include <mega16.h>
    #include <stdlib.h>
    #include <delay.h>
    #include <io.h>
    #define ADC_VREF_TYPE 0x40
    #define USART_BAUDRATE 9600
    #define BAUD_PRESCALE (((12000000/ (USART_BAUDRATE*16))) - 1)
    void ADC_init(void) // Initialization of ADC
    ADMUX=(1<<REFS0);
    ADCSRA=(1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);    // faktor pembagi 128
    void usart_init()
    UCSRB |= (1 << RXEN) | (1 << TXEN);   // Turn on the transmission and reception circuitry
    UCSRC |= (1 << URSEL) | (1<<USBS) | (1 << UCSZ0) | (1 << UCSZ1);
    // Use 8-bit character sizes
    UBRRL = BAUD_PRESCALE;
    // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
    UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value..
    // into the high byte of the UBRR register
    void usart_putch(unsigned char send)
    while ((UCSRA & (1 << UDRE)) == 0); // Do nothing until UDR is ready..
    // for more data to be written to it
    UDR = send; // Send the byte
    // Read the AD conversion result
    unsigned int ADC_read(unsigned char adc_input)
    ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
    // Delay needed for the stabilization of the ADC input voltage
    delay_us(10);
    // Start the AD conversion
    ADCSRA|=0b01000000;
    // Wait for the AD conversion to complete
    while ((ADCSRA & 0x10)==1);
    ADCSRA|=0b00000;
    return ADCW;
    void main(void)
    unsigned int value;
    DDRB=0xFF;
    DDRD=0x03;
    ADC_init(); // Initialization of ADC
    usart_init();
    // ch=0;
    while(1)
    value=ADC_read(0);
    value=value*500/1024;
    PORTB=value;
    //SEND_reading(value);
    usart_putch(value);
    delay_ms(10);
