Embedded and Microcontrollers
Embedded Forum Do you have a question on Embedded electronics and controls? Ask our Expert, Paul Clarke
  • Replies 126 replies
  • Subscribers 508 subscribers
  • Views 10544 views
  • skills
  • c
  • hvac
  • digital
  • engineer
  • expert
  • microprocessor
  • answer
  • control
  • thermal_management
  • embedded_system
  • embedded
  • thermal
  • electronics
  • paul_clarke
  • assembly
  • solutions
  • rac
  • software
  • develop
  • question
pjclarke
pjclarke over 14 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Embedded in the element14 Community Embedded group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Paul Clarke
Paul has 20+ years of working as a digital electronics engineer and has strong software skills in assembly and C for embedded systems. Currently developing embedded electronics for thermal management control solutions for the air movement industry (HVAC & RAC).
    Hello, mister paul,
    I have buy a programmer LEAPER-3DLEAPER-3D from farnell.
    I will programming a E-prom type M27C512-12F1M27C512-12F1.
    Which type select I with de programmer software.
    sorry of my englisch.
    Greet
    Piet Sijrier
  • pjclarke
    pjclarke over 14 years ago in reply to e14 Contributor
    Hi Piet,
    First off its nice to see someone still using 27C EPROMS!
    I assume you mean which chip to select from the list of manufactures? There should be a device listed under NEC, suggest you start with 12volt devices and see how if it verify's ok. I think from having a look around you will find your chip is a 12.75volt device - if you can check with manufactures datasheet.
    Paul
    e14 Contributor over 14 years ago in reply to pjclarke
    Hello Paul,
    Thanks of  your answer.
    But I have a other problem.
    I must select the type in de list of manufactures.
    I can select 27C5120-Q100 of the 27C512-N100.
    What is the difference?
    Greet,
    Piet Sijrier
  • pjclarke
    From what I remember these are Intel part numbers and that the N and Q relates possible to voltage or maybe somthing like packing type. The 100 in the gate time (100ns). Either should work, just chek voltages. It was always a little suck-it-an-see.
    Thank you
    Good day
    Hello Paul,
    I have question for the M27C512-12F1.
    Is it possible to retrieve the programming from the chip to understand the current process?
    During a recent building migration from one building to another a series of LED message boards where found, I want to update the system.  However, my knowledge and skill of electronics is minute. I know it could be a ambitious project.  I believe it would be great learning experience to update the system to use .NET Micro Framework on embedded system board to generate the messages.  The message would be updated using XeeBee wireless connection.  Nevertheless, I am getting ahead of myself.  The first task is to understand how the LED panels are controlled.
    The display sign employ 4 set of LED panels with each consisting of 12 (2 rows 6 columns) PARA LIGHT C-5580SRD (5 x 8).  Each panel is powered by 9 volts and daisy chained by 10 wire connection.
    michaelkellett over 14 years ago in reply to e14 Contributor
    Hello Steven,
    Googling suggests that the M27C512-12F1 is an EPROM. It's meant be read - so all you need is the data sheet. Of course reading the EPROM in a system won't get you far - you would need to know what the processor was and a full schematic as well. Can't you find the manufacturer of the panels and ask them how to use them ? Alternatively can you post some photos of the panel controller.
    e14 Contributor over 14 years ago in reply to michaelkellett
    Hello Michael,
    First, I must say “Thank You!” I appreciate you taking the time helping me understand. I should have realized that just reading the custom ROM would not provide all the answers.
    I have tried to locate the company of the DIGITAL-FAX unit without much luck. It seems the unit was built in 2000 (discovered from documentation for wiring a compute to the unit).   I took a series of photos and iPhone video of the controller and a display board. They can be reviewed at http://gallery.me.com/stevenulbrich/100040
    More Historical Information
    After searching, all I could find is the diagrams for connecting a dedicated PC to the message board.  The display is divided in to section a 3panels area for message and a single panel for a clock. The units receive the updates from a dedicated application install on a computer, then transmitted over a DB9 COM port (converted to RJ11 4-wire).  I created a simple diagram of the how the controller and LED display matrix panels are connected  (LED Message Board Overview).
    Steven
    Hello Steven,
    You now have a few options:
    1) if you have access to the PC application you could connect a panel to a PC and watch the RS232 traffice between the two and perhaps decode the protocol.
    2) the processor is a Z80 so you could get a set of development tools and try to reverse engineer the code  - this will be between difficult and very very difficult depending on how the code was written.
    3) reverse engineer the panels (so you can work out how to drive them) and make your own controller from scratch using modern parts - this might be the easiest.
    4) put a bit more time into trying to get hold of the original control protocol.
    If I were you I would spend a day or so on 4 and if that failed go for 3. The panels don't seem to have a processor so you should be able to figure out how they work.
    Hello Michael,
    Well this is going to be a great adventure. I hope that not a remake of the Odyssey.  I will try to reverse engineer the controller with up to date parts.
    Now, I have to start learning more and more.  I have decided to purchase some up to date component to help me learn the process.  SURE Electronics is offering a Demo Driver Board for 0832 Dot-Matrix Board can be used with the P4 32X16 RG Bicolor LED Dot Matrix Unit Board SPI.
    Do you have recommendations?
    Steven
