Embedded and Microcontrollers
Embedded Forum Has anyone come across a mini USB port with switched inputs?
  • Subscribers 502 subscribers
  • Views 268 views
  • connector
  • usb
  • mini
  • switch
   I'm designing an embedded product that features a mini usb port which we use for uploading/changing firmware but also for recharging the product's Li-ion battery. Has anyone come across an SMT mini USB connector that has switched inputs like you get on 1/4" audio jacks that allow for signal to pass through when there is no connection but switches that signal when you plug a connector in? What we're after is a way to leave the battery disconnected from the charger until a USB cable is plugged in. I can't find one but I thought someone here might have come across something.
Many thanks,
Robin
    You may want to go to the source to see it what you are describing conforms with the standard.
    http://www.usb.org/home
