Embedded and Microcontrollers
Embedded Forum ATTiny wont be programed using the AVRISP mII
  • Subscribers 502 subscribers
  • Views 434 views
  • board
  • bread
  • help
  • avrispmk2
  • breadboard
  • avrisp
  • avrisp_mkii
  • attiny
  • mii
for the last 4 hours i have been trying to get this simple circut to work so the attiny will be programed. I have taken the circut apart and put it back to gether 4 times. i tried putting a pull up resistor on reset. changing the servos. changing the attiny. my program builds and sends to the AVRISP MII fine so could someone please tell me how to hook up the avrisp to the tiny on a bread board. Ive looked at the pinouts of each a million times and i would really apreciate it if you could write it out.
    According to the data sheets for the AT tiny parts they use an interface called the TPI, tiny programming interface.
    Newark Part No.: 27W3730
    OLIMEX  AVR-ISP-MK2  FLASH PROGRAMMER, AVR MCU
    AVR-ISP-MK2 - OLIMEX - FLASH PROGRAMMER, AVR MCU | Newark element14 US
    Features: Program tiny AVR using TPI interface & mega AVR using ISP Interface
    hi
    1= take e reset pin with OSC when you trying to connect and in many cases this solve the problem.if this was the case change the pullup or add capacitors
    2=are fuse bits ok there are fuse bits (i dont recall their names) that may result in locking or disabling the micro (check atmel) and change your micro with a new one that are sure its new and working
    3= check avrfreaks and atmel for help
    I hope you get over it soon
    personally I hate it when micro doesn't connect seems like your hands are tied
