Embedded and Microcontrollers
Embedded Forum AVR ISP MII cant program ATTiny45.
  • Subscribers 502 subscribers
  • Views 265 views
  • cant
  • avr
  • 45v
  • help
  • isp
  • avrispmii
  • program
  • attiny45
  • 6
  • avrisp
  • attiny45v
  • code
  • avrstudio
  • please
  • attiny
  • 45
  • 6.1
  • studio
  • mii
I am using AVR studio 6.1 and the attiny45 isn't being programmed. Everything is set up. i've redone everything. the hook up from the ISP to the Attiny is ok. i have swapped the attimy 45 chip multiple times, so its not that.and i have a 4.7k pull up resistor on the reset line.
Here is my code:
#include <avr/io.h>
#include <avr/interrupt.h>
#include <inttypes.h>
#include <util/delay.h>
#define F_CPU 1000000UL
#define SERVO_DOWN 35
#define SERVO_UP 10
#define Outdoors 750
#define Indoors 600
int ReadADC();
int light = 0;
int main(void)
   DDRB |= (1 << 0);
   DDRB &= ~(1 << 4);
   PORTB &= ~(1 << 4);
   ADMUX |= (0 << REFS0);
   ADMUX |= (1 << MUX1) | (0 << MUX0);
   ADCSRA |= (1 << ADEN);
   TCCR0A |= (1<<WGM01) | (1<<WGM00);
   TCCR0A |= (1<<COM0A1);
   TCCR0B |= (1<<CS01) | (1<<CS00);
   while(1)
       Test();
void Test() {
    OCR0A = SERVO_DOWN;
    _delay_ms(2000);
    OCR0A = SERVO_UP;
    _delay_ms(1000);
Please Help
