Embedded and Microcontrollers
Embedded Forum Microchip for WI-Fi & PWM
  • Subscribers 502 subscribers
  • Views 1410 views
I want to build a illumination controller. But for that, I need a small Michrochip that uses Wi-Fi (Already integrated) and PWM. Do you know any Microchip that can cover my necesities?
Thank you!
    shabaz over 11 years ago +1
    Hi Esteban, Most microcontrollers support some PWM capability, but not many support 802.11. Perhaps the CC3200 is worth exploring. A getting started guide is here.
  • Workshopshed
    Workshopshed over 11 years ago +1
    Yes, the CC3200 would work for that. You could also look at the Arduino Yún Mini or go for a 2 board solution using your favourite micro-controller board with a Wifi module like the ESP8266, Dragino HE…
    e14 Contributor over 11 years ago in reply to shabaz +1
    Hi Guys, I am using the Arduino Yun for the prototype. But I was looking for something cheaper for production. Anyway, I will have to use microcontroller & Module by separate. I will use PIC12F1572 & RN171…
    0 shabaz over 11 years ago
    Hi Esteban,
  • Workshopshed
    0 Workshopshed over 11 years ago
    Yes, the CC3200 would work for that. You could also look at the Arduino Yún Mini or go for a 2 board solution using your favourite micro-controller board with a Wifi module like the ESP8266, Dragino HE or ATWINC1500
    0 e14 Contributor over 11 years ago in reply to shabaz
    Hi Guys,
    Anyway, I will have to use microcontroller & Module by separate. I will use PIC12F1572 & RN171.
    I really appreciate you took your time to answer my question.
    Thank you!
  • Workshopshed
    0 Workshopshed over 11 years ago in reply to e14 Contributor
    Looks like a good combination
