Embedded and Microcontrollers
Embedded Forum Where do I start  in embedded?
  • Replies 37 replies
  • Subscribers 504 subscribers
  • Views 4066 views
  • microcontrollers
  • embedded
majorkuso
majorkuso over 11 years ago
I would like to get better at building embedded devices but can't decide between avr or pic. I have the pickit 3 for pics and avr usbasp  and arduino. the arduino is ok, but I want to get closer to the metal. I would like some structured projects that I can build and familiarize myself with both the hardware and more importantly the c coding i would like to get better at my c. What would you guys recommend?
  • johnbeetem
    johnbeetem over 11 years ago in reply to dougw +2
    Caveat: PSoC4 and PSoC5 are great chips, but the PSoC Creator environment you need to design with them only runs on Microsoft Windows.
    DAB over 11 years ago +1
    Hi James, I would suggest the cypress Semiconductor PSOC 4 family. They have a great free development IDE plus they have programmable hardware for digital and analog circuits. They have a great range of…
    Jan Cumps over 11 years ago +1
    You can go to the very metal with that Arduino that you have. There's no need to invest.
  • majorkuso
    0 majorkuso over 11 years ago in reply to majorkuso
    I'm thinking about creating the reflow oven that ben heck did one with the Arduino and then later either the pic or avr
    0 michaelkellett over 11 years ago in reply to majorkuso
    Sounds  a good start - be careful with the mains switching - keep your processor stuff well separated and isolated from mains power - use an opto isolated solid state switch from a reputable source.  It's so easy when you are debugging the software to forget how deadly the mains voltages can be.
  • majorkuso
    0 majorkuso over 11 years ago in reply to michaelkellett
    I am aware of mains thank you though I am more hardware oriented than software that is why I guess I have a hard time with programming in general. I have some relays and high current mosfets to drive relay. I could use but I will probably get an ssr if I do not have any relays that can handle the current or voltage, I think the only factor will be current have to check.
  • majorkuso
    I know many people say to learn c first but in the embedded environmenmt I believe that would be overkill.
    0 Jan Cumps over 11 years ago in reply to majorkuso
    If you're going to write firmware in c, it would be a good idea to understand the language.
    You can do that in parallel while tinkering.
    Definitely use a ready made SSR - much safer and has built in opto isolation.
    And do learn C - very little embedded coding is done in assembler now - you can easily afford a processor which is supported by a decent C compiler and free tools are readily available.
  • majorkuso
    I have the following books that I am going to try absolute beginner's guide to C, Beginner's Guide to Embedded C Programming, C programming for microcontrollers, Make: AVR Programming: Learning to Write Software for Hardware.
  • majorkuso
    I wish that codecadamy had programs to learn c.
  • majorkuso
    I have been reading up on the differences between pic and avr I have read the avr is 4 times faster than the pic  executing one instruction per cycle how much of an impact would that have on a program
    None because it's meaningless - what matters is how much code per second and what that code can do !!
    There are Pics with quite fast clocks and 16 bit architecture - AVRs and megaAVRs are 8 bit architectures.
    The best book to learn C, and in the opinion of many, including me, the best programming book (on any language) ever written is: "The C programming Language" by Brian Kernighan and Dennis Ritchie.
    For simple projects AVRs or 16 bit PICs are both perfectly adequate.
    If you are choosing  a processor based on performance rather than you already having the tools you should consider ARM Cortex which offer by far the widest range of features/performance/suppliers of any architecture.
