Embedded and Microcontrollers
Embedded Forum DMA address
  • Subscribers 502 subscribers
  • Views 377 views
DMA address
i need to physical RAM memory test, in that case  i need to skip DMA address,Can you please tell me, how to find out DMA address which is mapped with physical memory and skip that physical address. i am want to add this code into my module.I am using linux 3.12 kernel.
  • fustini
    fustini over 10 years ago +1
    Hi, interesting to have a Linux kernel here I've gotten very interested in kernel programming after doing the The Eudyptula Challenge last year. What architecture are you on? This StackOverflow answer…
  • fustini
    0 fustini over 10 years ago
    Hi, interesting to have a Linux kernel here image  I've gotten very interested in kernel programming after doing the The Eudyptula Challenge last year.
    This StackOverflow answer applies to x86: http://stackoverflow.com/a/5748589
    DMA devices use bus addresses. On an i386 PC, bus addresses are the same as physical addresses, but other architectures may have special address mapping hardware to convert bus addresses to physical addresses.
    Cheers,
    Drew
