Embedded and Microcontrollers
Embedded Forum I need to connect 4 UART/Serial output from a single MUX, which Mux IC can I use ?
  • Subscribers 503 subscribers
  • Views 752 views
  • amgalbu
    0 amgalbu over 10 years ago
    Hi
    What is the uart speed? You to connect a TTL signal (0-5v) or to rs232 signal (-12 +12v)?
  • peterjcs23
    0 peterjcs23 over 10 years ago
    Use a 74LVC257 at the logic interface and add the line driver to the output.
  • amgalbu
    0 amgalbu over 10 years ago in reply to peterjcs23
    Hi peterjcs23
    74LV257 operates at 3.3V so may be it does not fit the design
  • peterjcs23
    0 peterjcs23 over 10 years ago in reply to amgalbu
    I'm pretty sure its 5V tolerant on its inputs.
  • amgalbu
    Hi peterjcs23
    Its tolerant on inputs but VCC max is 3.6v
  • peterjcs23
    it is possible to drop the 5V supply to 3.3V...Peter
