Embedded and Microcontrollers
Embedded Forum Can I integrate keil compiler with eclipse for compiling as well as debugging
  • Answers 2 answers
  • Subscribers 502 subscribers
  • Views 734 views
Can I integrate keil compiler with eclipse for compiling as well as debugging.
I want to write code in eclipse IDE as its editor is much powerful and user friendly with many feature set, which lags in keil IDE.
But i also want to debug the code in eclipse only, don't want to end up between switching IDE and debugger.
Please suggest...
    shabaz over 10 years ago +1 suggested
    Also, worth contacting Keil. They will have this information for you in detail. I'm sure they get this request many times so will have an answer.
  • clem57
    0 clem57 over 10 years ago
    You do not specify the embedded processor, but a good one includes a debugger in hardware. Check out Cypress PSoC series.
    Clem
    0 shabaz over 10 years ago
    0 e14 Contributor over 10 years ago in reply to shabaz
    0 e14 Contributor over 10 years ago in reply to clem57
