Embedded and Microcontrollers
Embedded Forum LPC4357-EVB write and read file to SD eMMC
  • Subscribers 502 subscribers
  • Views 532 views
  • lp4357-evb
  • emmc
  • lpc4357
  • sd
  • file
I'm using a  LPC4357-EVBLPC4357-EVB kit which has a SD eMMC interface I found this example that reads a WAV file from the SD and plays it
element14: Software Examples for SD Card on  LPC4357-EVB (Example 5)
However, I also need to write a file into the SD.
Does anybody have a simple example that manipulates files in a SD card, using the LPC4357?
Any tip wil be very helpful,
Thanks.
  • clem57
    0 clem57 over 10 years ago
    I would try this http://www.nxp.com/documents/application_note/AN10406.pdf .
    It is not the same processor, but it has the same interface.
    Clem
    0 e14 Contributor over 10 years ago in reply to clem57
    Thanks for your answer! With this example I could validate the interface between the SD and the LPC4357.
    However, this code access directly the eMMC blocks, and I need to access .TXT files from the SD card. Do you have any hint?
