Embedded and Microcontrollers
Embedded Forum chip cap
  • Subscribers 502 subscribers
  • Views 350 views
chip cap
I AM WORKING WITH CHIPCAP d-50 .. AND ITS WORK ON ZACWIRE WIRE PROTOCOL.. I DONT KNOW WHICH FUNCTION WILL READ THE VALUE THAT IS GIVEN BY THE CHIP.. AND HOW TO SHOW THE TEMP VALUE ON SERIAL MONITOR
    0 michaelkellett over 10 years ago
    Hello Bahul,
    You've posted the same question in two groups - please don't do this - pick one group and everyone can still see your question. Please use lower case - all upper case message are reserved for SHOUTING !
    You need to explain in much more detail what you are trying to do - what is the sensor connected to and what software do you have available to talk to it. We don't know what you mean by "serial monitor" - please explain - diagrams and pictures will help if you have trouble with English.
    Is there any reason you must use this sensor - the Zacwire protocol is not often used and you find it much easier to get code examples and  help if you use a sensor with an I2C interface.
