Embedded and Microcontrollers
Embedded Forum I2C Communications
  • Replies 14 replies
  • Answers 7 answers
  • Subscribers 503 subscribers
  • Views 2312 views
  • embedded c
  • arduino programing
  • stm-32
  • ewarm
  • how to i2c
  • 3-axis magnetometer
  • iar
I2C Communications
rbevy101
rbevy101 over 9 years ago
Hi guys! I have a sensor module that I am trying to use. I can't seem to get it working with I2C.
Does anyone have any tips or can anyone point me to any useful materials to help me make progress with this sensor?
The sensor is a 3 axis magnetometer.
Thanks!
  • koudelad
    koudelad over 9 years ago +3 suggested
    If you prefer a video tutorial, Ben Hack made one: www.youtube.com/watch Depending on how serious you are with electronics, I can recommend buying a logic analyzer (some cheap cost a few dollars). Or,…
  • clem57
    clem57 over 9 years ago +2 suggested
    You do not show any details, so a general tutorial may help https://learn.sparkfun.com/tutorials/i2c
  • koudelad
    koudelad over 9 years ago in reply to rbevy101 +1 suggested
    I've quickly gone through the linked datasheet and I think you only have to properly set MR_REG_M register in order to start measuring. By default (after reset), it is in sleep-mode.
  • clem57
    0 clem57 over 9 years ago
  • koudelad
    0 koudelad over 9 years ago
    Depending on how serious you are with electronics, I can recommend buying a logic analyzer (some cheap cost a few dollars). Or, some microcontroller programmers have support for various protocols analysis (UART, I2C, SPI).
    This allows you to test any new sensor/device with a piece of HW and SW that is proven to work and later makes it easier to debug your own HW and firmware. Almost all microcontroller families now have an integrated I2C module and most development environments have ready made libraries for it.
  • rbevy101
    0 rbevy101 over 9 years ago in reply to clem57
    https://www.adafruit.com/product/1120  This is the board itself
    https://cdn-shop.adafruit.com/datasheets/LSM303DLHC.PDF This is the datasheet
    I am trying to read the magnetometer.
    I have tried to use PSoC 4 kit in I2C to read the x axis values. When I am in debug mode in the PSoC creator I can't get any values returned when the device is being read. Every time I keep getting 0. The registers CRA_REG_M, CRB_REG_M, and MR_REG_M I beleive all need set for the calibration of the device. Am I correct in assuming this? Also is there a chance I have made a rookie mistake?
  • koudelad
    0 koudelad over 9 years ago in reply to rbevy101
  • koudelad
    To be honest, I am also struggling with debugging PSoCs in PSOC Creator. Compared to debugging PICs, it is quite limited. (Must go deeper to make sure I am not using it wrong.)
    That's why I recommended a logic analyser. You can easily read/write the entire memory of the sensor and quickly check all values against the datasheet.
    If you are interested, I can insert some working I2C code for PSoC 5LP (it is probably the same for PSOC 4) I used for a real time clock.
  • clem57
    0 clem57 over 9 years ago in reply to koudelad
    Here is example http://www.psocdeveloper.com/project/psoc4-i2c-communication/
  • rbevy101
    0 rbevy101 over 9 years ago in reply to koudelad
    Yea I ordered a logic analyser yesterday so i'm waiting on it coming. If you have code I would love to compare it to what I have!
  • koudelad
    The code below is the minimum I extracted from my project and should be general enough. I've worked with DS3232M RTC. The component name (placed in the design) is I2C and microcontroller used is some PSOC 5LP series.
    I am not sure about the original source, but I think this code comes from a Cypress application note (I've just opened a few, but couldn't find it). This code doesn't check for I2C component availability etc. and as provided is useless (nothing is done with the data). I only pasted the functions to perform a single read from the I2C slave device.
    #define I2C_WRITE 0u
    #define I2C_READ 1u
    #define RTC_I2C_ADDRESS 0x68 // I2C address of DS3232M (and some other RTCs)
    #define RTC_RAM_TD_LOCATION 0u // RAM location of current time and date
    #define RTC_NO_OF_BYTES_FULL 255u // number of bytes to read full RTC RAM
    void RTC_I2C_Read_RAM (unsigned char ramLocation, unsigned char bytesCount, unsigned char *i2cBuffer) {
        I2C_MasterSendStart(RTC_I2C_ADDRESS, I2C_WRITE);
        I2C_MasterWriteByte(ramLocation);
        I2C_MasterReadBuf(RTC_I2C_ADDRESS, i2cBuffer, bytesCount, (I2C_MODE_REPEAT_START | I2C_MODE_COMPLETE_XFER));
    uint8 i2cRTCReadBufferFull[256]; // buffer big enough to store full RAM of RTC clock
    int main(void)
        CyGlobalIntEnable; /* Enable global interrupts. */
        I2C_Start(); // start I2C component
        RTC_I2C_Read_RAM(RTC_RAM_TD_LOCATION, RTC_NO_OF_BYTES_FULL, i2cRTCReadBufferFull); // read the whole RAM of DS3232M
     for(;;) {;}
  • rbevy101
    I have a funny feeling I am reading the device wrong or else not sending the correct device data.
    #define MAG_ADDR (0x1E) // magnetometer 7 bit address
    #define MAG_ADDR_Read (0x1E | 0x01) // magnetometer 8 bit address
    #define MAG_ADDR_Write (0x1E | 0x00) // magnetometer 8 bit address
    #define CRA_ADDR (0x00) // Control Register A
    #define CRB_ADDR (0x01) // Control Register B
    #define MR_ADDR (0x02) // Mode Register
    #define X_AXIS_H (0x03)
    #define X_AXIS_L (0x04)
    /////////////////////////////////////////////////////////////////// i2c.c containing i2c functions //////////////////////////////////////////////////////////////
    uint8 mag_ReadReg(uint8 Reg){
        uint8 Write_Buf[1] = {0}; //buffer that contains the register we want to read from
        Write_Buf[0] = Reg;
        uint8 Read_Buf[1] = {0};
        // step 1
        I2C_1_I2CMasterWriteBuf(MAG_ADDR, (uint8 *)Write_Buf, 1, I2C_1_I2C_MODE_NO_STOP);
        while((I2C_1_I2CMasterStatus() & I2C_1_I2C_MSTAT_WR_CMPLT) == 0){}
        // step 2
        I2C_1_I2CMasterReadBuf(MAG_ADDR, (uint8 *)Read_Buf, 1, I2C_1_I2C_MODE_REPEAT_START);
        while((I2C_1_I2CMasterStatus() & I2C_1_I2C_MSTAT_RD_CMPLT) == 0){}
        return Read_Buf[0];
    // step(1) the register address that you write to
    //     (2) the value you wish to write to the register
    void mag_WriteReg(uint8 Reg, uint8 value){
        uint8 Write_Buf[2]={0};
        Write_Buf[0] = Reg; // register to write to
        Write_Buf[1] = value; // value to write to register
        I2C_1_I2CMasterWriteBuf(MAG_ADDR, (uint8 *)Write_Buf, 2, I2C_1_I2C_MODE_COMPLETE_XFER);
        return;
    ///////////////////////////////////////////////////////////////main.c//////////////////////////////////////////////////////
    int main(void)
        I2C_1_Start();
        uint8 deviceID[1]={0};
        uint8 CRA_Before, CRA_After, CRB_Before;
        CRA_Before = mag_ReadReg(CRA_ADDR); //register before written to
        mag_WriteReg(MR_ADDR, 0x00); // register written to
        CRA_After = mag_ReadReg(CRA_ADDR); // register after written to
        for(;;)
            deviceID[0] = mag_ReadReg(MR_ADDR);
    I keep trying to watch the variables CRA_BEFORE and CRA_AFTER to see is the register has changed. I keep getting <optimized out> in the watch window where there should be values.
  • rbevy101
    I found out my problem. All is working now! Thank Goodness
