Embedded and Microcontrollers
Embedded Forum hot glue gun problem
  • Subscribers 503 subscribers
  • Views 615 views
  • hot_glue
  • hot glue
  • gun
  • glue
  • glue gun
p.katsos
p.katsos over 9 years ago
Hi
I have a huge problem. I bought a hot glue gun yesterday and I used it today.
It worked well but after I stoped using the gun, glue continued flowing. I don't know what to do to solve this problem.
can anybody give me some advice on how to solve this?
    jw0752 over 9 years ago +4 verified
    Hi Panagiotis, I have found that over flow is to be expected. Sometimes I will pull back slightly on the glue stick to ensure there is no positive pressure. I also unplug the gun shortly before I am done…
    dougw over 9 years ago +1
    You might try dipping the tip in cold water after unplugging.
    0 jw0752 over 9 years ago
    Hi Panagiotis,
    I have found that over flow is to be expected. Sometimes I will pull back slightly on the glue stick to ensure there is no positive pressure. I also unplug the gun shortly before I am done using it so that it begins to cool and coasts to the point where I am finished. Finally I always expect it to run and drip so I prepare by putting on a glass surface so that I can easily clean up any over run.
    0 dougw over 9 years ago
