Embedded and Microcontrollers
Embedded Forum Standardisation?
  • Replies 17 replies
  • Answers 8 answers
  • Subscribers 504 subscribers
  • Views 2513 views
Standardisation?
Workshopshed
Workshopshed over 9 years ago
Following on from a discussion about the Intel Edison being discontinued I got thinking about what could be used as a replacement for longer lifetime projects. The Pi compute module was mentioned but that form factor is a single supplier again. I understand you can get suppliers to sign up to longer term support but that's no good unless you are one of the big companies.
So I was wondering if there were any small form factor standards for processor boards that would allow you to have multiple supplier options?
I spotted Smarc 2.0 which has a option for 82 mm × 50 mm boards https://www.sget.org/standards/smarc.html
and
96Boards IOT (which only has 2 boards and one supplier at the moment) - 96Boards - Internet of Things Edition
    shabaz over 9 years ago +3 suggested
    Hi Andy! Really good topic. I think there was such a discussion a few years ago, but time has moved on and this topic is worthwhile examining from fresh with current information. From my perspective, I…
    DAB over 9 years ago +3 suggested
    Hi Andy, Interesting post. Board size is usually determined by the functions implemented. I think that was the key reason for the Arduino, TI, BeagleBone, and RPi support boards. Each vender determines…
  • Workshopshed
    Workshopshed over 9 years ago in reply to shabaz +2 suggested
    >I feel the availability for the parts and ease-of-use for using the parts and associated software is more important than the pin compatibility I was thinking a bit more than just the pinout, the form…
    0 DAB over 9 years ago
    Hi Andy,
    Interesting post.
    Each vender determines the market they want to support and develop a capability based upon those initial requirements.
    In my experience, there is little coordination between venders and I have not found much interest between them to define or comply with a standard.
    I think this is mostly due to the rampant  'Not Invented Here" syndrome that is rampant within each company.
    There are some venders that do support multiple platforms by creating a interface conversion board across multiple products to support their specific sensors or devices.
    I think that is the best you can hope for.
    There is just too much competition and preference for proprietary products (read Apple here) that makes the maker environment very difficult, though not impossible.
    As they say, "Where there is a will, there is a way!"
    Just a thought.
  • Workshopshed
    0 Workshopshed over 9 years ago in reply to dougw
    Douglas, I was thinking standard between boards so you could swap them out if one supplier let you down.
    0 mcb1 over 9 years ago
    Long term availability is an issue.
    Unless you design the board yourself using a single processor and keep quite a few in stock, you tend to be at the mercy of the suppliers.
    Even with open source, you're still relying on a chip manufacturer to a degree, but it does give options.
    Thankfully Arduino can enjoy a long life until Atmel stop making the chips.
    Many of the basic boards are so cheap that having several in your collection for spares is now possible.
    The FRDM boards are cheaper than you can get the parts for, so using them in a design allows for 2-300% spares, as long as you keep copies of the tool chain and source/compiled code.
    Whenever I do an article for TheShed, I always look for resources that are available to the other readers, which tends to rule out special samples.
    Like it or not the Raspberry Pi and Pi Zero would appear to have a produced a defacto footprint board that has endured a few years and has open source OS and tools.
  • Workshopshed
    0 Workshopshed over 9 years ago in reply to mcb1
    Good point on the Pi, I've used Pi phats with different boards and I saw that there is a Microbit to Hat adapter now too.
    Also just spotted this board from last year - http://www.insight.tech/industrial/a-ferrari-in-the-raspberry-pi-world
    0 mcb1 over 9 years ago in reply to Workshopshed
    Looks interesting.
  • Workshopshed
    Update: Orange Pi have brought out a 96boards board and Libre Computer a Pi pin compatible board.
    Via MickMake
    https://youtu.be/Vrb4SIvJE6o
    0 shabaz over 9 years ago in reply to Workshopshed
    Interesting board! Nice that it has an antenna connector for more practicality when fitting in an enclosure.
