Embedded and Microcontrollers
Embedded Forum PIC controller
  • Answers 3 answers
  • Subscribers 503 subscribers
  • Views 813 views
  • pic controllers
  • microchipdirect
  • embedded hardware
PIC controller
yadhu22krish@gmail.com
yadhu22krish@gmail.com over 9 years ago
HI,
I dont have  much knowlwdge in programming....Is it possible to connect two pins internally for a microcontroller ? Iam using pic32mzef.
    dougw over 9 years ago +3 suggested
    PSoC microcontrollers from Cypress Semiconductor allow connection of internal functions and they provide the programming tools to make it easy to accomplish.
    michaelkellett over 9 years ago +1 suggested
    It is very unusual to be able to connect pins internally. Check the data sheet to see if yours is an exception but I don't think it will be. I've quite often needed to connect pins on prototypes (to correct…
    0 michaelkellett over 9 years ago
    I've quite often needed to connect pins on prototypes (to correct errors) and I just solder very thin wires to the pins. Make sure your code doesn't end up with two outputs driving each other.
  • saravananeceait
    0 saravananeceait over 9 years ago
    Its not possible
    0 dougw over 9 years ago
