Embedded and Microcontrollers
Embedded Forum Kit
  • Subscribers 504 subscribers
  • Views 703 views
Kit
fatkitkat
fatkitkat over 8 years ago
Hello all, i am new to this forum and very much a novice and need assistance trying to find this Subminiature Relay with Farnell
please could i ask for some assistance  in finding this Power Relay its comes from a Hotpoint Washing Machine PCB
Its labeled  as below and i have also attached some pics.
HF3FD
012-Z3F(088)
10A 250VAC 85 oC
6A 250VAC 105 oC
China TH26
Many Thanks in Advance i really do appreciate any help as i am trying to repair this myself due to lack of funds otherwise i can
get a complete PCB but its not possible atm.  Cheers
Relay.image
  • gam3t3ch
    gam3t3ch over 8 years ago +3 suggested
    Found lots on ebay and aliexpress so just have to find the one with the best rep and shipping by the looks of it. Other then that there might be local places you could check out appliance repair shops…
  • gordonmx
    gordonmx over 8 years ago +1
    Kit, Aside from EBay, I couldn't find the exact part either, but I did find the latest data sheet ( http://www.hongfa.com/pro/pdf/HF3FD_en.pdf ). As you can see, the China manufacturer is Hongfa. The latest…
  • gam3t3ch
    0 gam3t3ch over 8 years ago
    Found lots on ebay and aliexpress so just have to find the one with the best rep and shipping by the looks of it.   Other then that there might be local places you could check out appliance repair shops shouldn't cost much for the part.
  • gordonmx
    0 gordonmx over 8 years ago
    Kit,
    Aside from EBay, I couldn't find the exact part either, but I did find the latest data sheet (http://www.hongfa.com/pro/pdf/HF3FD_en.pdf ).  As you can see, the China manufacturer is Hongfa.  The latest data sheet does not cover the -Z3F suffix, but it should give you enough information to help you find an replacement part.  The HF3FD/012-ZSTF should work fine and is available through Future Electronics. The -xSxx specifies a plastic sealed part, and since you are hand soldering, should be ok.  The -Z3F has AgNi contacts, where the -xxTx has AgTnO2 contacts.  I hope this helps, good luck.
    Gordon
  • fatkitkat
    0 fatkitkat over 8 years ago in reply to gordonmx
    Thank You Gene and many many thanks Gordon.  It was that i was not able to source in the UK a HF3FD-012-Z3F but only a HF3FD/012-ZSTF i was not sure if this Relay would do the job.
    I appreciate the help and will give it a go.  I it does not then i will get a PCB. Wish me luck and Thanks again.
