Embedded and Microcontrollers
Embedded Forum how much ram a 32-bit machine can address?
  • Answers 3 answers
  • Subscribers 504 subscribers
  • Views 764 views
  • microcontroller?
  • embedded system
jatinjain12
jatinjain12 over 7 years ago
if a processor is 32 bit then how much ram will it support?
  • Fred27
    Fred27 over 7 years ago +4 suggested
    If you mean how much memory can be addressed by 32 bit then that's about 4GB.
  • james.flynn
    james.flynn over 7 years ago +3 suggested
    on its face the answer as others have said is 2^32 = 4294967296 but often, a memory management unit (MMU) is present that allows this to vary. A good overview of the MMU is at: https://en.wikipedia.org…
  • e14softwareuk
    e14softwareuk over 7 years ago +2 suggested
    It will depend on the processor. For example not all address lines might be available from the chip so the physical addressable memory will be less than 4GB. Alternatively the processor may support paged…
  • Fred27
    0 Fred27 over 7 years ago
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    It will depend on the processor. For example not all address lines might be available from the chip so the physical addressable memory will be less than 4GB. Alternatively the processor may support paged memory and thus theoretically there is no upper limit to the amount of physical ram that could be supported. For example I believe some 32-bit Intel CPUs supported 36-bit physical addressing.
  • james.flynn
    0 james.flynn over 7 years ago
    on its face the answer as others have said is 2^32 = 4294967296 but often, a memory management unit (MMU) is present that allows this to vary.  A good overview of the MMU is at: https://en.wikipedia.org/wiki/Memory_management_unit
