Embedded and Microcontrollers
Embedded Forum What is Blink register?
  • Subscribers 503 subscribers
  • Views 1401 views
  • embedded microcontroller
  • microprocessor
jatinjain12
jatinjain12 over 6 years ago
  • clem57
    clem57 over 6 years ago +1
    www.youtube.com/watch A quick google gave me this above. jatinjain12 is that what you mean?
    michaelkellett over 6 years ago in reply to jatinjain12 +1
    Why don't you post the context as I suggested - we have no idea which processor you might be using - if you would post a link to the document that you don't undertsand we could helo you properly instead…
  • johnbeetem
    johnbeetem over 6 years ago in reply to jatinjain12 +1 verified
    A number of computer architectures use a https://en.wikipedia.org/wiki/Link_register to store the return address for a subroutine call. The instruction set typically has a "Branch And Link" instruction…
    0 michaelkellett over 6 years ago
    I think we need a bit more context to answer this.
    Post the text or code i (or alink to it) that is puzzling you.
  • jatinjain12
    0 jatinjain12 over 6 years ago in reply to michaelkellett
    it is with respect to CPU registers. like PC , SP.
    Probably Blink keeps the address of that instruction to be loaded in PC after it returns from function.
    but not sure hence i put this question here.
  • clem57
    0 clem57 over 6 years ago
    0 michaelkellett over 6 years ago in reply to jatinjain12
    Why don't you post the context as I suggested - we have no idea which processor you might be using  - if you would post a link to the document that you don't undertsand we could helo you properly instead of guessing.
  • johnbeetem
    0 johnbeetem over 6 years ago in reply to jatinjain12
    A number of computer architectures use a https://en.wikipedia.org/wiki/Link_register to store the return address for a subroutine call.  The instruction set typically has a "Branch And Link" instruction that jumps to an address and simultaneously stores the return address in a link register.  For example, the IBM 360/370 has a "BAL" instruction.  ARM and PowerPC have a "BL" instruction.  There are also versions of these instructions for when the target address is in a register, such as "BALR" and "BLR".
    Some architectures have a single dedicated link register (LR).  Others allow any register to be used, but one is usually used by convention.
    Hope this helps!
