Embedded and Microcontrollers
Embedded Forum How to drive a 5V relay with 3.3V ?
  • Subscribers 503 subscribers
  • Views 816 views
navadeepganeshu
navadeepganeshu over 6 years ago
Lot of modules and devices today run on 3.3V and they do not have 5V peripheral at all!
How to drive a 5V generic relay with these?
(are level shifters, boost converters an option?)
    jw0752 over 6 years ago +4 suggested
    Hi Navadeep, Every spare USB battery has a circuit in it that converts the 3.7 volt battery voltage to 5V for USB power. These circuits are called DC to DC boost converters. You should be able to find…
    0 jw0752 over 6 years ago
    Hi Navadeep,
    Every spare USB battery has a circuit in it that converts the 3.7 volt battery voltage to 5V for USB power. These circuits are called DC to DC boost converters. You should be able to find a variety of them available on ebay. You will not need a very powerful one if all you want to energize is a relay. It will be a good idea to put a diode across the output so the spike from the relay coil doesn't damage the converter.
