Embedded and Microcontrollers
Embedded Forum Digital pressure sensor needed
  • Subscribers 503 subscribers
  • Views 453 views
  • gauge
  • pressure
  • knode
  • measurement
  • sensor
Latch
Latch over 14 years ago
I have a project that will require an electronic pressure gauge.
Here is what is must do or handle:
- Temp range -40 - +150
- Accuracy +/- 1%
- 0-150 psi (0-10bar)
- Battery operated
- 3-4 digit display, 3/8" - 1/2" character height (Or a LCD of similar size)
Due to space limitations I cannot use a standard mechanical gauge. (unfortunate for me).
This digital solution will replace a mechanical one. All the adapters and mechanical pieces I can make. I just need help sourcing a digital gauge.
Thanks in advance.
Latch
  • Latch
    0 Latch over 14 years ago
    Optimally, I would want the pressure sensor to connect via a 1/8" NTP.
    Latch
    This one probably takes the same space as an analog gage.
    NOSHOK - 1000-145-2-1 - Digital Pressure Gauge
    You may also want to consider a sensor and a panel meter.
    VDO IMT - 3296075001 - PRESSURE TRANSMITTER, 0-10BAR
    ANALOG PANEL METER, CROMPTON MODEL#E244-05R-G-HG-**,RANGE: 4-20 MADC, SCALE: DUAL: OUTER- 0-200 PSI, INNER- 0-14BAR
    Panel Meter Services
